technical question about oil consumption.
Old Jul 2, 2008 | 04:45 PM
gsrcolt's Avatar
Default technical question about oil consumption.
I have a 95 Integra GSR B18C1, I just replaced the engine, because i sucked water into my cold air intake and put 4 holes in the block on cylinder #1.... yeah, that sucked!!!! So bought this used long block for $1200 our cost (shop) The engine runs great, but when in vtec comes in under acceleration, the is smoke from the exhaust (oil). I have exactly 175 psi compression on all four cylinders. Mitchell OnDemand 5 says that 130 psi is service limit and 200 psi is great.... i done a leakdown test yesterday and 2 3 and 4 have massive leaks.... on 4 the leak is coming from 3's spark plug hole and on 3 the leak is from 2's hole and on 2 the leak is from 3's hole... what the heck? Any ideas? Valve guides maybe?
Old Jul 2, 2008 | 05:55 PM
DonF's Avatar
Default Re: technical question about oil consumption. (gsrcolt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrcolt &raquo;</TD></TR><TR><TD CLASS="quote">I have a 95 Integra GSR B18C1, I just replaced the engine, because i sucked water into my cold air intake and put 4 holes in the block on cylinder #1.... yeah, that sucked!!!! So bought this used long block for $1200 our cost (shop) The engine runs great, but when in vtec comes in under acceleration, the is smoke from the exhaust (oil). I have exactly 175 psi compression on all four cylinders. Mitchell OnDemand 5 says that 130 psi is service limit and 200 psi is great.... i done a leakdown test yesterday and 2 3 and 4 have massive leaks.... on 4 the leak is coming from 3's spark plug hole and on 3 the leak is from 2's hole and on 2 the leak is from 3's hole... what the heck? Any ideas? Valve guides maybe? </TD></TR></TABLE> As the valves are closed when you do a "leak-down" test it will tell you nothing about the guides or valve seals. You have a bad head gasket or did not do the test properly, I side with the second choice.
gsrcolt
21
Jul 9, 2008 07:42 PM
gsrcolt
Jul 3, 2008 09:35 AM
gsrcolt
Jul 3, 2008 06:57 AM
gsrcolt
May 28, 2008 07:52 PM
profuse007
May 22, 2007 05:41 AM
