ARP head studs/Cometic HG combo
Old Jul 14, 2008 | 05:27 AM
hawaii_boi_808's Avatar
Default ARP head studs/Cometic HG combo
I have a regular ls engine with these two items: the ARP head stud kit with a 81MM Bore - MLS .030" Head gasket made by Cometic, and i was wondering what torque specs should i follow. In my Chilton manual it says to torque the head bolts in two steps all the way to 63 ft. lbs. and in the sheet that was included with my head stud kit it says "Following the manufacturers recommended torque sequence tighten the nuts in three equal steps to <U>80</U> ft lbs with ARP MOLY ASSEMBLY LUBRICANT" Everyones info, personal experience, and knowledge is welcomed. I was also wondering whether or not more torque would be needed to compensate for the size of the gasket.
Old Jul 14, 2008 | 06:07 AM
Mikey3000's Avatar
Default Re: ARP head studs/Cometic HG combo (hawaii_boi_808)
use the torque spec that ARP gives. also, the more steps you use the better. i did mine in 20 lb/ft increments til i got to 80.
Old Jul 14, 2008 | 07:08 AM
Default Re: ARP head studs/Cometic HG combo (Mikey3000)
thanks for the quick response and advice...now i can get to work
gonmaro
Jan 29, 2009 12:05 PM
roger93si
Jan 16, 2007 10:12 AM
roger93si
Jan 16, 2007 02:14 AM
adam8103
Mar 21, 2006 02:53 PM
saso
Jun 3, 2002 02:57 PM
