Compression during break-in
Old Jul 6, 2008 | 02:57 PM
astralshadow's Avatar
Default Compression during break-in
I know that during breakin when you check for compression you're just measuring consistency and not really how high the numbers are. I have a newly rebuilt motor, have not turned it over yet but decided to do a test before wiring it up. Starting from cyl #1 I got, 155-128-150-100, is this normal until the engine has its first combustion? Or could my valve lash be bad on a few cylinders
Modified by astralshadow at 12:43 PM 7/7/2008
Old Jul 6, 2008 | 03:09 PM
Default Re: Compression during break-in (astralshadow)
oh and also these are wiseco pistons, with a cap full of oil in each cylinder before testing
Old Jul 6, 2008 | 04:35 PM
1992Si's Avatar
IMO the rings are not seated yet.
Start the engine and break it in.
Old Jul 7, 2008 | 08:42 AM
After about how many miles should the readings become consistent across the board?
Old Jul 7, 2008 | 11:02 AM
1992Si's Avatar
Most people don't worry about it if it runs good.
Don't over think this.
Old Jul 7, 2008 | 12:44 PM
DonF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by astralshadow &raquo;</TD></TR><TR><TD CLASS="quote">I know that during breakin when you check for compression you're just measuring consistency and not really how high the numbers are. I have a newly rebuilt motor, have not turned it over yet but decided to do a test before wiring it up. Starting from cyl #1 I got, 155-128-150-100, is this normal until the engine has its first combustion? Or could my valve lash be bad on a few cylinders
Modified by astralshadow at 12:43 PM 7/7/2008</TD></TR></TABLE> I fyou do not know if the valve lash is bad on a few cylinders, do not start it, ADJ. your valves.
Old Jul 7, 2008 | 02:57 PM
Default Re: Compression during break-in (DonF)
Thanks for the input guys Don, valve lash can't be terribly off considering how **** I was about it measuring, but if I hear the slightest bit of ticking I'll shut that thing down immediately. But maybe you're right to give it another once-over before starting. Hopefully I'll get time this weekend to crank it up, I'll keep posted incase anyone else has the same questions
chuisek9
Sep 9, 2007 11:01 PM
mjrage
12
May 28, 2004 03:20 PM
Droppedatbirth!
15
Feb 2, 2004 06:36 AM
DOHCarp
Sep 11, 2003 07:10 PM
311
Dec 14, 2002 12:18 PM
