Question about ARP head stud install
Old Jul 8, 2008 | 10:44 AM
Project_EK's Avatar
Default Question about ARP head stud install
Is it a good idea to tap (clean) the threads in the block for the head studs?? the threads are fine & not stripped, but it's prolly a good idea to clean em up?! also what are u guys torquing ur head studs to using the moly lube?? (GSR engine built for boost 28PSI) i'v done 75FT LBS in other builds and that seems to work fine, but none of those builds were on high boost..
thanks
Old Jul 8, 2008 | 11:13 AM
inspyral's Avatar
You're supposed to use a thread chaser to clean out the threads, since a tap could potentially cut some of the existing threads out. If you do decide to use a tap, use plenty of lubrication oil and proceed carefully to avoid cutting any of the existing threads. My B18B studs are 7/16" with 1/2" head nuts, and the torque spec for them is 70lb ft with ARP moly lube, and 80 with oil. If the GSR studs are the same diameter, then I would assume the torque spec is the same. If you have any doubts, verify on the spec sheet that came with your studs.
Old Jul 8, 2008 | 11:36 AM
Project_EK's Avatar
any links to where i can find a thead chaser online?? thanks for ur help
Old Jul 13, 2008 | 07:19 PM
ltrkstr2k's Avatar
Default Re: (Project_EK)
we always used a stock head stud as the chaser just make sure its clean and not full of dirt in the treads
1990_integra_DA9
May 19, 2008 04:57 PM
BlueTeg
16
Feb 4, 2007 11:47 AM
kabaroo
10
May 21, 2005 10:41 AM
Dammit_Dan_954
Jan 3, 2004 12:50 AM
SCsol
Mar 23, 2002 06:39 PM
