cam gears
Most Honda cams have a hex cast into them where you can use a wrench to hold it. If you can't find that, then most cams also have a hole cast into them that's used to lock the cam at TDC while in the head. This hole lines up with a hole in the cam cap, and you insert a 5 or 6mm punch to hold the cam in place at TDC. You can theoretically use this hole to hold the cam while loosening the cam gear bolt, but be advised that there have been cases of people snapping this piece off of B18A/B cam caps, so be careful if you have an LS. The B series VTEC heads have this hole in a thicker part of the cam cap cover plate, so it isn't as much of an issue. If you have access to air tools, then an impact wrench would probably be your fastest option for removing the bolts. Just make use you use something soft to wrap around the cam while holding it in place, preferably with a vise or something.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superfast666 »</TD></TR><TR><TD CLASS="quote">yeah there is a spot for a open ended wrench</TD></TR></TABLE>
i feel dumb because i inspected the cam and didnt see anything
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Importlove »</TD></TR><TR><TD CLASS="quote">Use an air gun.I had a friend with one do mine.Works like a charm.</TD></TR></TABLE>
i have a air gun, but let my friend barrow it, the problem then will be how do i tighten it?
ill have to check, the thing is the head is off the car, i might have to step on the head just so it doesnt turn but ill try that, but like i said mu concern now is how will i tighten them back up?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1BADEGDC2 »</TD></TR><TR><TD CLASS="quote">
thats cause there isnt a spot on h22 cams
when i took my cam gears off i stuck a wrench through the gear and lodged it under the cap next to the gear where it has the bolt for the VC, but to tighten it i wouldnt know my cam gears have the key cast into it so i wasnt able to install my jun gears
Modified by AlmostJDM at 1:36 PM 7/9/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1BADEGDC2 »</TD></TR><TR><TD CLASS="quote">didnt think so! i looked at the cam like 20 times 20 ways!</TD></TR></TABLE>
Can you take a photo of the cam gears ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AlmostJDM »</TD></TR><TR><TD CLASS="quote">
Modified by AlmostJDM at 1:36 PM 7/9/2008</TD></TR></TABLE>
You can buy keys at the hardware store or Auto Parts stores.
yea im gonna be going to get some friday, even though im going to wait to put the gears on until i buy some jun cams to go along with the JUN gears, valve springs and retainers
OrangeBoost
13
Apr 25, 2006 06:50 PM
