Aluminum cleaning
Old Jul 4, 2008 | 07:32 AM
slvrcvc93's Avatar
Default Aluminum cleaning
Anyone know a good way to clean an engine with out having to take the engine to get sand blasted? I wanna clean a single cam before i put it in the car but not sure which way would be the best ? I have a pressure washer but i know that wont do the trick alone.
Old Jul 4, 2008 | 12:44 PM
hotrod99's Avatar
Default Re: Aluminum cleaning (slvrcvc93)
Simple Green!
Spray it on, let it sit for about 5-10 mins, then spray the stuff off with a high pressure washer, or a waterhose with a pressure nozzle. Make sure you cover the battery/intake (if aftermarket or exposed) and the distributor (water can get inside the cap).
Old Jul 4, 2008 | 07:28 PM
vtecb18c's Avatar
Default Re: Aluminum cleaning (hotrod99)
simple green worx on anything lol...yea some simple green to clean it and some mothers polish to make it shine
Old Jul 4, 2008 | 07:43 PM
slvrcvc93's Avatar
Default Re: Aluminum cleaning (vtecb18c)
thanks guys im gonna try it cant hurt I have a pressure washer so lets see what happens
Old Jul 5, 2008 | 01:40 AM
JDMInspired's Avatar
lmk how simple green goes. ive tried it and didn't take off that much corrosion off my head. im thinking of using a wirebrush and/or sandpaper
Old Jul 5, 2008 | 03:47 AM
thatkid's Avatar
The only thing that's going to get the corrosion off is going to be sandpaper, or a wire wheel on a drill or something.
Old Jul 5, 2008 | 08:48 AM
slvrcvc93's Avatar
Default Re: (thatkid)
well today its raining so I dont feel like going outside and getting wet so i will try to do it tomorrow i already have simple green 2 one gallon bottles but i do have a wire wheel just in case.
Old Jul 7, 2008 | 03:26 AM
axlnut's Avatar
Default Re: (slvrcvc93)
Hydrofloric acid, the white corrosion your seeing is calcium. Hydrofloric acid will draw this out and removes it. Its whats referred to as "acid" or "brightner" in commercial vehicle wheel cleaners. You must be very careful with it though, just google and read up. The results are stunning, your motor will look brand new, a very nice shiny natural bright aluminum color, like it just left the factory or a machine shop.
Modified by axlnut at 12:37 PM 7/7/2008
Old Jul 7, 2008 | 08:03 AM
slvrcvc93's Avatar
Default Re: (axlnut)
I knew that the corrosion was calcium and I actually bought a liquid drain cleaner that is acid based for the cleaning.
Its not the same as the one your telling me but im pretty sure there has to be somewhere i can get the chemical locally without having to get it from online.
Old Jul 8, 2008 | 09:55 AM
BrownDx's Avatar
I just did mine.
Simple green and a powerwasher will work.
Old Jul 8, 2008 | 10:56 AM
slvrcvc93's Avatar
Default Re: (BrownDx)
Ill post my piture later but ill be honest wasnt 2 impressed with the results it was cleaner but wasnt like new.
TheNasty0ne
Aug 26, 2005 04:27 PM
xiLLtegRax
Sep 15, 2004 08:12 PM
SL!M
Apr 19, 2003 07:23 PM
EF-9SiR
Mar 10, 2003 04:56 PM
95hybridcivic
Jul 10, 2002 06:34 PM
