Transmission / Clutch Problem. HELP!
Old Jul 9, 2008 | 01:17 PM
snowblind7x's Avatar
Default Transmission / Clutch Problem. HELP!
i just changed out my clutch on my H22 and it starts up fine but when i release the clutch my car dies even though in neutral. Anyone have any idea why this is happening?
Old Jul 9, 2008 | 03:28 PM
1992Si's Avatar
Sorry dude, I've been thinking about this for an hour... IDK
If you let the clutch out slowly what happens ?
Does the car want to move with the shifter in neutral ?
Are you positive your have the correct clutch set up. Call the MFG and verify you have the correct one.
Old Jul 9, 2008 | 04:06 PM
Default Re: (1992Si)
Yeah, this is really a tough one, never had anything like this happen in all my years of tech work. Car doesn't move, I've even put the car on jackstands, started it up, and tried to accellerate but the wheels will not spin, not even a 1/1000 turn . Car does the same thing if you let it out slow, let it out fast, etc; RPMS just drop like it's in gear...
Old Jul 9, 2008 | 04:19 PM
1992Si's Avatar
Does the shifter feel normal ?
It must be stuck in between gears.
Subaru's do that.
Old Jul 10, 2008 | 02:00 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1992Si &raquo;</TD></TR><TR><TD CLASS="quote">Does the shifter feel normal ?
Subaru's do that.</TD></TR></TABLE>
yeah the shifter feels normal. i can shift through all gears no problem
Old Jul 10, 2008 | 02:14 AM
Extradition's Avatar
Default Re: Transmission / Clutch Problem. HELP! (snowblind7x)
Are you sure you have a transmission? It sounds like a transaxle problem to me... You sure that exedy even sent you a clutch setup? I've had bad business with them, they're a shitty company. I doubt you'll ever fix your car man, I've heard preludes are pieces of ****... My homie who owns a prelude has the same exact thing happening with his car, but no idea what's going on either; good luck!
Old Jul 10, 2008 | 02:15 AM
Mador's Avatar
Default Re: (snowblind7x)
Have you tried started the car in gear, revving while releasing the clutch? any response?
Old Jul 10, 2008 | 04:41 AM
1992Si's Avatar
Default Re: Transmission / Clutch Problem. HELP! (Extradition)
Wow sorry to hear you had problems with exedy.
We had one of there clutches wear out once and they gave us a new set up.
OP what kind of clutch is it, you need to call them. You did buy it new didn't you?
Old Jul 12, 2008 | 01:55 AM
Default Re: (Mador)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mador &raquo;</TD></TR><TR><TD CLASS="quote">Have you tried started the car in gear, revving while releasing the clutch? any response?</TD></TR></TABLE>
yeah the wheels dont spin at all and it'll still end up diein.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1992Si &raquo;</TD></TR><TR><TD CLASS="quote">Wow sorry to hear you had problems with exedy.
exedy stage 1 clutch. it's brand new and the exact same one i took off so i know its the right onw.
Old Jul 12, 2008 | 03:23 AM
1992Si's Avatar
I'm thinking take it back apart and try to reinstall it.
There's no odd sounds when its running ?
Check the clutch release assembly.
Something must be put together wrong.
vinceg143
Aug 20, 2008 03:24 PM
Eyger
Honda Civic (2001 - 2005)
Aug 18, 2008 07:45 PM
arkytec
Mar 10, 2004 06:49 AM
92-EG6
Aug 25, 2003 10:02 PM
taytay333
Nov 21, 2001 12:58 PM
