clutch problem
Old Jul 16, 2008 | 09:23 AM
mike272's Avatar
Default clutch problem
Hi
I've tried searching and cross posting this in the Prelude forum.
I have an 86 Prelude (fuel injected) and the clutch has stopped disengaging. I've tried adjusting it and replacing the clutch cable. After replacing the cable it worked ok but only for 2 shifts, then the problem returned.
Any ideas/suggestions?
If I have to replace the clutch, any hints/tips? How long will it take me?
Thanks in advance...
Mike
Old Jul 16, 2008 | 10:01 AM
vtecb18c's Avatar
Default Re: clutch problem (mike272)
yea sounds like your clutch is gone...how long will it take you? well how much experience do you have working on cars and how accessible are you to tools?
Old Jul 16, 2008 | 10:23 AM
mike272's Avatar
Default Re: clutch problem (vtecb18c)
Thanks.
Car is actually a Hornet class race car and currently is at the track. My pref is to do the work there but could get it back to my place (clean covered garage, lift etc) if necessary. Bit of time, bit of money, in each direction. We've replaced a steering rack last night and a head gasket the week before for a different car at the track.
Experience and tools ... I have some experience and a pretty good selection of tools. With the help of my 2 buddies who have quite a bit of RWD experience but none of us have much FWD (but we're learning) I think we should have sufficient expertise to tackle the project. None of us have replaced a clutch in a FWD but they have both done it for RWDs. So the "how long" question is more about when we schedule doing this. Doing work at the track in the evening after work ... daylight can be an issue. So how long should it take for someone to do this the first time if they have reasonable mechanical abilities and tools?
Thanks again.
Old Jul 16, 2008 | 10:42 AM
vtecb18c's Avatar
well with having 3 people that are mechanically inclined it shouldnt take you long at all...,being as its your first time i would say a good full day and it should be done....you really only have to drop the trans side of the motor if you dont wanna yank it out...just remember the flywheel needs to be resurfaced before you put the new clutch in...your RWD buddies shouldnt have any problem its very simular..instead of pulling the driveshaft, their pulling axles
Old Jul 16, 2008 | 11:05 AM
mike272's Avatar
Thanks!
Old Jul 16, 2008 | 11:08 AM
vtecb18c's Avatar
no prob let me know how you make out
Old Jul 18, 2008 | 04:39 PM
turbocivic1984's Avatar
how did the clutch change go? or what was wrong?
Old Jul 19, 2008 | 11:06 AM
richcon82's Avatar
Agreed
Im thinking clutch is pretty much
gone. When it does work and you
disengage the clutch out of first
you will feel some major chatter
if its gone. But I could be wrong :D
Old Jul 20, 2008 | 04:50 PM
acura1652's Avatar
i have been having probs with my clutch pedal stick half way...
ethereal2pt2
Nov 7, 2006 02:07 PM
jeffruby
Apr 16, 2006 11:48 PM
skrewdlude
Nov 3, 2003 06:55 AM
civic_sir94
Dec 1, 2002 10:42 AM
