What is my problem?
Old Jul 12, 2008 | 11:12 PM
FukinCrx's Avatar
Default What is my problem?
Sup Everyone,
I am looking for some help with a possible ecu problem. I recently installed a b16a into the crx and have not been able to get it to start. The first time I went to start the car it blew the 14a fuse and the 8A fuse. I replaced these fuses and it blew them several times, so I decided to do some troubleshooting. I replaced the under dash fuse box with another one and the fuses stopped blowing, but car wouldn't start. Then I decided to replace the main relay and the car still doesn't start. Today, I checked all grounds and made sure that they were properly tightened, everything checked out fine. I decided to check the black/yellow power wire running to the ecu to make sure it was getting power and that checked out fine. I did notice that CEL light does not light up on the dash, reverse lights do not work, turn signals do not work, and clock. My main concern right now is just getting the engine to turn over. In addition to all that I have mentioned, I noticed the relay does click twice when key is turned to the on position, and the ecu light flashes once in the on position. The car gets no fuel or spark. Any direction you could possible lead me or suggestions on what to check next?
Thanks
Old Jul 13, 2008 | 07:06 PM
vtecb18c's Avatar
Default Re: What is my problem? (FukinCrx)
well considering all the things that are wrong, you should try swapping ecu's with someone you know(if they have one)...it may be fried
Old Jul 14, 2008 | 04:44 PM
FukinCrx's Avatar
Default Re: What is my problem? (vtecb18c)
Tried a new Ecu and same thing, any other suggestions?
mike03,95civic
Dec 31, 2008 08:11 AM
TeamRiskEG6
29
Aug 7, 2008 05:53 AM
FukinCrx
Jul 20, 2008 01:08 PM
si90rex
Jun 24, 2007 05:53 PM
curiousgpnoy
Jan 3, 2004 11:15 AM
