I need help in regards to a battery relocation....please!
Old Jul 11, 2008 | 03:13 PM
qbansir's Avatar
Default I need help in regards to a battery relocation....please!
can anyone please help me out? I have EVERYTHING connected correctly. The battery has juice i know for a fact! I have the battery grounded and i made sure that the terminal has a good connection. Now on the positive side i have two cables...one goes straight from the positive terminal on the battery itself to the starter. The other cable running from the positive terminal goes straight to the fuse box. The first time i had everything connected, I when inside the car and i had power, so i tried to start it up and the starter clicked once. After that...i have no power WHATSOEVER...i checked all the fuses and they are good and I also disconnected the ecu to see if that would help...I reconnected everything but im back at square one...no power to anything!!!
Any input would be greatful....cuz now im stuck at home....with no working car lol....
Old Jul 11, 2008 | 03:20 PM
qbansir's Avatar
Default Re: I need help in regards to a battery relocation....please! (qbansir)
bump
Old Jul 11, 2008 | 03:21 PM
downeyballz's Avatar
where is the battery grounded?
Old Jul 11, 2008 | 03:28 PM
qbansir's Avatar
Default Re: I need help in regards to a battery relocation....please! (downeyballz)
to the CHASSIS...well actually the front crash beam
Old Jul 11, 2008 | 07:09 PM
qbansir's Avatar
anyone....?
Old Jul 12, 2008 | 05:31 PM
4d_POWER's Avatar
If your fuses are good it sounds like a dead battery or broken/corroded connection to the fuse block.
good luck!
Old Jul 12, 2008 | 06:11 PM
1992Si's Avatar
I don't think the battery goes straight to the starter, it goes to the under hood fuse box. I think.
When we moved our battery the car started fine.
It sounds like you have 3 wires from the battery ?
Old Jul 12, 2008 | 06:15 PM
qbansir's Avatar
Default Re: (1992Si)
OK PEOPLE...i got it fixed!!! MAKE SURE YOU GUYS HAVE A GOOD GROUND!!!
Im such a [freak]in idiot!
Old Jul 12, 2008 | 06:17 PM
1992Si's Avatar
Default Re: (qbansir)
Agree LOL
CgClam
Apr 21, 2019 06:13 PM
UrVtecIsLoud
Dec 7, 2008 12:09 PM
qbansir
Jul 13, 2008 07:37 PM
sleepin91teg
May 29, 2004 11:53 AM
EF Two
Oct 3, 2003 08:39 PM
