Painting engine/transmission??
Old Jul 6, 2008 | 09:02 AM
turboedsupe's Avatar
Default Painting engine/transmission??
So i figured while im doing my swap i should clean everything up. I wanted to paint the engine and tranny a charcoal color. I couldnt find anybody with this color in high temp. paint except this place http://www.hightempenginepaint.com/ . Anyone used this paint before? Also how much precaution do i need to take? Someone was telling me you cant paint because the mettalic in the paint would make the engine ground out and run crappy. I was figuring just clean it up real good then tape off any needed areas and then spray away. Any advice will help
Old Jul 7, 2008 | 05:25 AM
Default Re: Painting engine/transmission?? (turboedsupe)
Old Jul 7, 2008 | 09:56 AM
vtecb18c's Avatar
im sure that paint will work fine...and like you were planning on doing, just take little peices of tape and cover where the grounds have to be
Old Jul 7, 2008 | 10:53 AM
1992Si's Avatar
Also don't paint the area where the block meets the tranny, that's a ground path.
Old Jul 7, 2008 | 11:00 AM
vtecb18c's Avatar
Default Re: (1992Si)
x10^^ good call
JScott3d
Paint and Body
Mar 10, 2008 09:23 PM
mugencx
Paint and Body
Nov 25, 2007 07:45 PM
SlobberGoat
Aug 21, 2005 08:46 PM
G'd_up
Honda S2000
May 12, 2005 01:15 PM
