High Comp. Hesitates. No Power. Runs hot. Dies Up Top
These are some of the issues I am having with my car.
I did a compression check and it was 225 psi all across, with 8.5:1 pistons
The car with bog/hesitate just when its about to come out of vacuum, anywhere from 5"hg and 0.
The power band is completely pushed up in RPM range and all power dies up top. I used to make 240 TQ by 5k and hold that 240 to redline and now i just make it at 6800 and it immediately dies off.
And it also seams to run slightly hotter
Any ideas?
Any ideas?
Re: High Comp. Hesitates. No Power. Runs hot. Dies Up Top (superfast666)
Sorry, i should have stated my set up before.
ls/vtec W/ pistons and rods
gsr head/tranny
revhard turbo kit
1000cc injectors
tuned with hondata
gsr head/tranny
revhard turbo kit
1000cc injectors
tuned with hondata
Re: High Comp. Hesitates. No Power. Runs hot. Dies Up Top (rdssk8rcs1)
so its boggin out on the top end sounds like fuel but you have huge injectors maybe its a fuel pump or pressure regulator
Heres my old dyno sheet @ 15psi....
And heres my new dyno sheet on the same exact set up except bigger injectors...
Modified by rdssk8rcs1 at 11:17 PM 7/7/2008
PINKS
07-09-2006 10:46 PM
PINKS
36
07-09-2006 05:34 PM
ic108
12-08-2001 07:30 PM
