i need help with my motor setup!!
Old Jul 16, 2008 | 02:31 PM
R3DxLIN3's Avatar
Default i need help with my motor setup!!
ok so i went an got my motor tuned and dynoed today!!
i juss put a skunk 2 pro 2 cam with pro valve trian! except for stock valves..
i have headers and cool air intake and ****!... stock si's dyno at 130 whp i had one hour of tuning and was at 155whp.. this is with STOCK ECU
anyways.. with these cams i found out i need higher compression! so i figured id ask you guys to help me out!
i was thinking about buying a b18c1 block(GSR) and build it with some high compression pistons and maybe a new crank! Then when its built throw my b16 head with the already built valve train onto it!
i wanted to know if this would be a good way to go or just build up a b16 block?!?
any other suggestions would be helpful!!!
i want to do this right!!
98NAIntegra
42
Sep 25, 2008 06:53 AM
EkFG
17
Jul 9, 2008 09:47 PM
Green JDM-R
Mar 8, 2007 06:18 AM
Jesterian
20
Jan 17, 2006 03:46 PM
jdm_redneck
Feb 5, 2004 09:35 PM
