Oil Cooler Questions...
Old Jul 4, 2008 | 07:29 AM
acrocat's Avatar
Default Oil Cooler Questions...
I'm thinking about installing an oil cooler in my car. I have looked at the mfactory kit and it looks really nice but i was wondering if i put together my own kit would i have to use -10 line or could i use -6... just would like to hear some oppinions about both.... i am considering getting an oil cooler with fan and installing a thermostat too... i tried searching but couldnt find any good info about the affects on oil pressure and stuff with different size line. My car is boosted and i am planning on getting a new turbo so i would like to install an oil cooler at the same time. Any help or input would be great
Old Jul 4, 2008 | 08:32 AM
welfarepc's Avatar
where are you going to install the oil cooler? i was thinking about putting one before my turbo
might do the install tomorrow
i use 1/4in lines (-4) to feed my turbo
Old Jul 4, 2008 | 09:56 AM
inspyral's Avatar
You run the risk of an oil pressure drop if you run smaller oil cooler lines.
Old Jul 4, 2008 | 12:20 PM
welfarepc's Avatar
oil pressure drop to what? your turbo and oil cooler?
doesnt sound too bad to me.
Old Jul 4, 2008 | 01:01 PM
superfast666's Avatar
Default Re: (welfarepc)
he meant is oil pressure drop in your motor that sounds real bad to me welfarepc
Old Jul 4, 2008 | 04:33 PM
acrocat's Avatar
i guess it sorta makes sense you want a free flowing oil cooler setup so it runs through the oil cooler as fast and easy as possibly and makes it back into the motor. but i still wanna see what some other people say... mfactory says that oil pressure stays about the same with their kit.
I want to mount my oil cooler where the passenger side foglight would mount.
Old Jul 4, 2008 | 07:00 PM
welfarepc's Avatar
i see the concern. i plan on running a restrictor at the end of the line, so there should be some back pressure
people who run remote oil filters dont seem to have a problem either.... and thats PRE filter and post filter.
id like some feedback on this for sure
Old Jul 5, 2008 | 10:39 PM
fourthgenhatchB17's Avatar
I run -10 lines, no thermostat, a remote mounted Wix filter, and a Setrab cooler. I do have an oil psi gauge hooked up and I didnt notice any significant drop in pressure after the install.
A friend of mine runs -8 lines, has a thermostat, with the same cooler but without a gauge. His seems to be performing just fine.
I dont think i would run something as small as -6 line. I also think a fan on the cooler is a bit overkill, but if u did want one i would think the cooler would have to be quite big in order to strap a fan on it. IIRC my cooler is a 16 row. I also have an oil temp gauge and my temps rarely get over 210 unless im stuck in traffic with 95+ degree temps.
GT500FTW
Feb 13, 2013 10:40 AM
tremor86
Jan 13, 2005 10:26 AM
TurboDragger
Aug 29, 2002 05:46 AM
Smashback
Aug 15, 2002 08:44 AM
rice4life
May 9, 2002 06:57 AM
