WTF! Did my motor seized?
Old Feb 3, 2002 | 12:30 PM
hatchy's Avatar
Default WTF! Did my motor seized?
I haven't driven my car in a week, it has been sitting in my garage. Today, when I went out to start it, it didn't start. Battery is good (12.35v), no check engine light, but when the key is in the start position, I hear the starter solenoid click each time I turn the key, so I guess my wiring and fuses are good, but the starter never kicks in. Has my engine seized?
Since this has never happened to me before, How do I verify if my motor has seized or if I just have a bad starter without yanking out the starter?
Can I put my car in gear, pupoo poo 10 feet and see if it "frees" the motor? Any suggestions apprecaited. Thanks
[Modified by hatchy, 9:50 PM 2/3/2002]
[Modified by hatchy, 9:51 PM 2/3/2002]
Old Feb 3, 2002 | 01:28 PM
FSTASNTZ's Avatar
Default Re: WTF! Did my motor seized? (hatchy)
Take the starter out, and see if you can turn the engine by hand. You may just have a dead spot in the starter. Taking it off and turning the engine by hand will let you know if the motor itself is seized...
Jason
Old Feb 3, 2002 | 02:02 PM
Bbasso's Avatar
before u go crazy, Push start it and see before you get messy
Old Feb 3, 2002 | 02:06 PM
racerxadam's Avatar
Default Re: WTF! Did my motor seized? (Bbasso)
12.35 volts is acctually considered a dead battery almost. fully charged it shoud read almost 12.8 volts.
Old Feb 3, 2002 | 03:57 PM
hatchy's Avatar
Default Re: WTF! Did my motor seized? (racerxadam)
If it was the battery, the starter would at least start clicking.. but that isn't happening. The starter makes no movement whatsoever.
Old Feb 3, 2002 | 03:59 PM
hatchy's Avatar
Default Re: WTF! Did my motor seized? (FSTASNTZ)
Can I just push my car around in gear and see if the motor spins?
Old Feb 3, 2002 | 05:22 PM
Kamin's Avatar
its easier to get a big socket and stick it on the crank pulley bolt and see if the motor turns. gotta give it a little force tho
Old Feb 3, 2002 | 06:12 PM
hatchy's Avatar
Default Re: WTF! Did my motor seized? (KAMiN)
I put the car in 1st and rocked the car back and forth and the cam gears seems to move back and forth... so I guess my motor isn't seized, right?
Old Feb 3, 2002 | 08:28 PM
Kamin's Avatar
i wouldnt worry about your motor seizing. they dont just do that because they sat for a week.
check your starter, change your battery. and that clicking, are you sure its not the fuel pump turning on?
Old Feb 3, 2002 | 10:56 PM
hatchy's Avatar
I think my motor may have seized because I suspect the rings on the motor are going out, and the motor isn't very healthy to begin with anyway...
Yeah, the clicking (it is one semi-loud click each time I turn the key to the start position) is from the starter solenoid. The fuel pump is fine.
Old Feb 4, 2002 | 08:56 AM
typer_801's Avatar
I'd get a jump and see if that allows you to start it. In my year of employment at an auto dealership the only time I ever remembered hearing clicking noises was on cars with weak batteries. That's the first thing I'd recommend, then start looking at the more obscure causes.
Old Feb 4, 2002 | 09:01 AM
sgT's Avatar
sgT
Just jump start it
Old Feb 4, 2002 | 09:18 AM
SiR Kid's Avatar
New User
Default Re: WTF! Did my motor seized? (sgT)
Weak battery or a bad connection... Clean your battery terminals, tighten them down TIGHT, and try again.
$20 says it's a bettery/connection issue.
Old Feb 5, 2002 | 06:13 AM
Greyout's Avatar
Default Re: WTF! Did my motor seized? (SiR Kid)
omg a dead battery turns into a page-long tech post....
Old Feb 5, 2002 | 06:59 AM
4doorRS5spd's Avatar
New User
Default Re: WTF! Did my motor seized? (JDM LUDE)
It is probably the starter. My mother in laws starter went out on her '94 Accord, and when she turned the key, all she heard was clicking, similar to what you are experiencing.
Old Feb 5, 2002 | 12:42 PM
Kataku2K3's Avatar
Default Re: WTF! Did my motor seized? (accord55)
Yea my retarded *** friend drove his hatch through a 6" puddle like five times going 25mph. Then his died and did the same thing (when you try to start it it, the starter just made a lil clickin noise. His battery was reading 12.6v so i figured it was okay). I told him to try to pop start it but he said it wouldn't work so i went to his house and tried it. The second i let out the clutch the car screached to a halt. I just figured he seized his motor or something. But i don't really care cuz he's a freakin ***!
Old Feb 5, 2002 | 01:16 PM
98EK4's Avatar
Default Re: WTF! Did my motor seized? (JDMspecEG6)
A fully charged battery is 13.6-13.8 volts
at 12.5 they are considered dead
Old Feb 5, 2002 | 07:32 PM
hatchy's Avatar
Default Re: WTF! Did my motor seized? (98EK4)
You do know that there is a reason they call it a 12 volt battery, right?
Old Feb 5, 2002 | 07:34 PM
hatchy's Avatar
It turned out to be a dead starter. Replaced it. Starts fine now.
Old Feb 6, 2002 | 06:48 AM
98EK4's Avatar
Yes i do know that
And To tell you another thing the reason they say 12 volts is what they rate it at. Not the normal operating voltage.
Just like in a house voltage in outlets are 120 volts but they call it 110.
a 240 volt circut is also rated at 220
so if you want to get Technical I can get technical
Old Feb 7, 2002 | 11:49 PM
hatchy's Avatar
Funny how a "dead battery" starts my car every morning. Technically, that is pretty cool, eh? Go to Radio Shack and buy a volt meter, and figure it out. I'll give you a hint: Take a reading with the car OFF.
Yes i do know that
Treyschls
Jul 29, 2015 06:21 PM
DriveSlowHomie
Jan 26, 2010 10:31 PM
Touge Tuning
May 3, 2006 11:14 AM
Chief Brody
Honda Motorcycles
22
Jul 30, 2004 04:00 PM
ghost_ryder35
Mar 19, 2004 10:51 AM
