help tranny/clutch asap
Old Feb 1, 2002 | 01:25 PM
Kamin's Avatar
Default help tranny/clutch asap
https://honda-tech.com/zerothread?id=123001
sorry delete this post needed more detailed title.
[Modified by KAMiN, 11:16 PM 2/1/2002]
Old Feb 1, 2002 | 01:40 PM
Spade's Avatar
Default Re: help tranny/clutch asap (KAMiN)
check clutch fluild level and master cylidners for leaks.
If there are none then, the clutch is gone man......sorry.
[Modified by Spade, 2:41 PM 2/1/2002]
Old Feb 1, 2002 | 01:47 PM
Kamin's Avatar
Default Re: help tranny/clutch asap (Spade)
it would be the clutch tho..damn.
i installed a flywheel before i did my swap and the clutch has been working for almost 1000 miles now
would it be possible that its installed wrong?
Old Feb 1, 2002 | 01:48 PM
Spade's Avatar
I am fairly certain that you would have felt something right away if it was installed improperly.
What is the clutch fluid level like? They may have damaged the lines and caused a slow leak.
d16z6 eg6
Sep 16, 2009 02:36 PM
sheBangZ
Oct 16, 2007 05:04 PM
EG2Driver
Sep 30, 2006 05:30 AM
Superman137
Feb 17, 2006 02:02 PM
