OBD 0 pinouts
Old Feb 3, 2002 | 10:39 AM
Kataku2K3's Avatar
Default OBD 0 pinouts
Hey, i was just wonderin how you read OBD 0 pins. I've gotta drop my friends B16A into his CRX. I've done a lot of OBD 2 swaps and i know that the pins go from left to right A1, A2, A3, A4 and so on. I also have done OBD 1 and know that the pins go up, down, up, down. Thanks for the help!!!
Old Feb 3, 2002 | 01:23 PM
tinkerbell's Avatar
Default Re: OBD 0 pinouts (JDMspecEG6)
i dont think there is anything called OBD 0
but if you are refering to JDM wires for B16A check the link below.
the plugs should have some numbers on them, eg the start and ends of a sequence...
you should also be able to work out the sequences from the colour codes on this chart: http://<a href="http://www.geocities...gines.html</a>
i hope this is will help you.
t..
Old Feb 3, 2002 | 01:56 PM
Giuseppe's Avatar
Default Re: OBD 0 pinouts (tinkerbell)
non-OBD pr3, pwo
looking at the ECU without it being plugged into the harness
A1 A3
A2 A4
hth
Old Feb 4, 2002 | 11:33 AM
Kataku2K3's Avatar
Default Re: OBD 0 pinouts (Giuseppe)
Thanks Giuseppe!
ZRose
Nov 21, 2007 08:08 PM
blksir
Jun 14, 2005 10:28 PM
SpoolnG2
Jul 27, 2003 02:32 PM
the JigGa mAn
Jul 1, 2003 08:57 PM
DIY_Racing
Sep 27, 2002 09:41 AM
