del Sol in the 12's?
Old Feb 7, 2002 | 03:35 PM
fastestdriver's Avatar
Default del Sol in the 12's?
Any idea on how much power is needed to get a del Sol in the 12 second range?
Assume slicks, lsd, radius arms, overall good traction. Car is not lightened.
Old Feb 7, 2002 | 03:38 PM
drifter's Avatar
Default Re: del Sol in the 12's? (fastestdriver)
Probably around 230whp
Old Feb 7, 2002 | 04:49 PM
1stGenCRXer's Avatar
Default Re: del Sol in the 12's? (drifter)
Built CRVTEC with large cams would get you in the low 13's, throw a lite turbo on it and you should be there
Old Feb 7, 2002 | 09:53 PM
BTR ALL MOTOR's Avatar
i got a del sol thats supposed to hit mid-high 12's when its broken in......a whole lot more than lsd, and good traction though.....a WHOOOOLEE lot more....if you want ill tell you what my setup is over im or somethin....
Old Feb 8, 2002 | 07:01 AM
94DelSolVTEC's Avatar
Default take a look at darksol
There is a soler in texas by the name of dark sol. He ran a 12.9 and hes all motor no nos. He has a eg2 with a jdm teg type r. He redlines at 9,700 rpm. He has more titanium than anything ive ever seen. Here is what he has done to his car. http://www.darksol.com/showcase.html
Old Feb 8, 2002 | 08:33 AM
sgT's Avatar
sgT
Default Re: del Sol in the 12's? (1stGenCRXer)
If are hitting low 13s with a crvtec then that motor is blown
Old Feb 8, 2002 | 09:55 AM
Default Re: del Sol in the 12's? (sgT)
"car not lightened" 5th gen hatch on street tires will run mid-high 13's, a del sol is not significantly lighter to warrant a drastically faster time. Now, add cams to the crvtec, and you can take off about a half second + or - a tenth or two. So to recap, that's still high 12s or low 13's. Turbo a properly built CRVTEC and you'll be knocking on mid-high 10's.
Old Feb 8, 2002 | 10:05 AM
Charles B.'s Avatar
www.angelfire.com/tx2/brandonflynn
This is an old site I found in my favorites. It's Brandon Flynn's website. I'm not sure if he goes on this board, but his 93 Del Sol ran a 12.8@106mph boosting 10PSI with STOCK LS motor and modified SOHC GReddy turbo kit. No need for LSD, B20, LS/VTEC, blah, blah, blah. etc.
[Modified by SuperDuperEG, 7:06 PM 2/8/2002]
eddiedelsol
16
Dec 23, 2006 01:27 PM
locote
Jul 28, 2006 12:37 PM
asmallsol
Nov 3, 2003 12:30 PM
DELsolsKICK
72
Jul 19, 2003 06:23 AM
RICE POLICE SIP
192
Jan 23, 2003 03:13 PM
