Flywheel bolt size?
Old Feb 3, 2002 | 01:44 PM
AmauryR's Avatar
Default Flywheel bolt size?
Hi ppl.
I'm removing crap off my b-series motor and I've taken off the clutch (10mm 12pt) but I would like to know the size of the bolts that hold the flywheel (??mm 12pt), I don't have a set of 12pt sockets (cept for 1), so if you guys know offhand what size it is, that'd be appreciated.
Old Feb 3, 2002 | 01:51 PM
Kamin's Avatar
Default Re: Flywheel bolt size? (SKiLLz-R)
its a normal metric bolt, nothing special.
just go through the set of sockets till you find one that works i wanna say 14 but i could be wrong.
Old Feb 3, 2002 | 01:53 PM
shamoo's Avatar
Will you make something up for me please?
It's a 12pt 17mm.
You're lucky I have my flywheel sitting on my garage floor with the bolts. I ran down to check it out.
EDIT: Kamin, that's what I thought too....just go thru them. But he said he only has one 12pt, so I guess he wants to know what it is so he can go buy/borrow it.
[Modified by shamoo, 5:55 PM 2/3/2002]
Old Feb 3, 2002 | 03:36 PM
AmauryR's Avatar
Default Re: Flywheel bolt size? (shamoo)
Yep, unfortunately I only have 1 12pt socket (10mm), I'd appreciate it if you can get me the right size, I was thinking 14mm too.
Old Feb 4, 2002 | 09:34 AM
shamoo's Avatar
12pt 17mm....
EDIT: Oh okay, I just got your IM.
[Modified by shamoo, 1:34 PM 2/4/2002]
Old Feb 4, 2002 | 09:36 AM
Kamin's Avatar
oHHHH!
now it makes sense lol
my bad
Old Feb 4, 2002 | 09:39 AM
AmauryR's Avatar
Default Re: Flywheel bolt size? (KAMiN)
oops, (can't read well in da wee hours of da morning)
Old Feb 4, 2002 | 10:28 AM
Crazydave's Avatar
Well there is something special about the bolt head..
they are wider than "normal" bolts.. and
have flatter / or shorter heads" so they don't hit the clutch
Old Feb 4, 2002 | 11:20 AM
Kataku2K3's Avatar
Default Re: Flywheel bolt size? (Crazydave)
Yea it's a 17mm 12 pt.
brusk13
Oct 10, 2005 09:19 PM
dremmel
10
May 4, 2005 12:27 AM
endlessdv
Jan 27, 2005 11:22 PM
leprechan117
Mar 21, 2003 12:39 PM
Blaze45
Mar 5, 2003 03:09 PM
