? For those that have used Eagle rods
Old Feb 1, 2002 | 10:59 AM
badCRX's Avatar
New User
Default ? For those that have used Eagle rods
I have heard people say you just use the green bearings, I've heard others say to replace with the original colors used on the origina rods, or is there no fool proof plan other than to put them in and plastiguage them?
I'm putting together my CRVTEC and am needing to get some bearings ordered. Also, is the stock LS/CRV bearings used or is there anything better than that?
Thanks in advance.
Old Feb 1, 2002 | 11:30 AM
sgT's Avatar
sgT
Default Re: ? For those that have used Eagle rods (badCRX)
They are machined to a #3.
Use that as a starting point but plastigage is the best way to go.
Stock bearings are best
Old Feb 1, 2002 | 01:58 PM
badCRX's Avatar
New User
Default Re: ? For those that have used Eagle rods (sgT)
My stock rod bearings were yellow except for one which used green. That blew me away. I'll start with green ones and maybe order a spare set of yellow ones if needed.
Thanks Stephen.
Old Feb 1, 2002 | 02:38 PM
sgT's Avatar
sgT
use the rod # and crank letter to find your starting point.
Old Feb 3, 2002 | 01:09 AM
PyroVTEC's Avatar
New User
While we're on the topic of Eagles here... is it necessary to notch the block to make the rod clear?
Old Feb 3, 2002 | 03:34 AM
SlickTech's Avatar
Likewise, stock bearings are just fine. If you really want to be sure stop by a local parts shop that does some machining and check the bore sizes between the stock rods and the Eagles, unless you have a gauge on hand. Make sure both rods are torqued to spec. The last time I used them the bore sizes we identical to the stock rods. And of course; always, always, always plastigauge after you assemble.
Corksil
Dec 21, 2009 07:31 PM
h2beg
Feb 18, 2008 08:29 PM
djickabod
Dec 27, 2003 03:14 PM
EKweezy
Oct 8, 2003 10:09 AM
