Is my R too low???
Old Feb 7, 2002 | 03:57 PM
SpoonFed's Avatar
Default Is my R too low???
My suspension setup is Koni 5 way adjustables, set all the way up and Neuspeed Sport springs 2.5 drop ... Installed Ingalls kit and still hitting the fender and A arm ipoo pooing the top of the metal where the shocks mount in making a dimple....People say its too low and I need to go with a 1.5-2.0 springs...I dunno.... Any suggestions...thanks..Help
Old Feb 7, 2002 | 05:15 PM
976's Avatar
976
New User
Default Re: Is my R too low??? (spoonfed)
Adjust/raise your struts.
Aftermarket wheels? Off set needs to be correct.
Correct camber, toe, or alignment?
Things to consider...
Old Feb 7, 2002 | 06:27 PM
Erik_Pb_Foot's Avatar
New User
Default Re: Is my R too low??? (w00t!)
something isn't set right with the shocks.... is my guess
do you have the front spring perch on the upper or lower snap ring location? do you have a pic? i have mine on the lower perch with sportline springs and i don't really hit/scrub.... unless i have the shocks set soft.... i usually keep them set rather firm though. i'd also suggest a little negetive camber up front to help cornering and clearance.... not a lot though
OneZero1010101
May 29, 2004 03:51 AM
gsrpilot8000
Mar 3, 2004 09:19 AM
Solipsist
Nov 13, 2002 06:28 PM
GSblueRacing
Mar 1, 2002 09:30 PM
