Need help on how to install a transmission
Old Feb 4, 2002 | 04:09 PM
del la sol's Avatar
Default Need help on how to install a transmission
I'm going to put a JDM Integra Type R transmission into my 00' civic si, i also have to install a new clutch into it... does anyone know where i can find step by step instructions preferably one with pictures
Old Feb 4, 2002 | 04:17 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: Need help on how to install a transmission (del la sol)
I didn't look thru them...but here are a few sites with instructions:
http://www.c-speedracing.com http://www.bseries.net
Basically, if you want to do it yourself, just take a look at the tranny carefully. Basically you have to unbolt the tranny from the motor, and take off the two tranny mounts. It's not that hard....just a pain and it's time consuming.
Make sure you take off your starter too, otherwise it won't come off. When every bolt has come off.....make sure you really shake that thing to get it off.
The hardest part is removing the hub from the axle.....you need a special tool for it, otherwise you're gonna mess up the joint. Look at those sites, there should be an axle section too.
hmooblis
Oct 1, 2006 08:23 PM
solk1dd
Aug 4, 2005 06:59 PM
team2n1hatch
Dec 2, 2003 09:24 PM
del la sol
Feb 5, 2002 07:52 AM
