type r suspension on eg
Old Feb 4, 2002 | 05:19 PM
peebrain's Avatar
Default type r suspension on eg
im getting a hold of a full type r.
i want the suspension from it for my eg....but i need the car to roll...so the question is...what all do i need to take off the type R...and can i fit stock civic suspension back onto the type r...nothing perfect...but enough to roll good...i know what you are all thinking, but its legit...and i want to take advantage of this option.
so again...
what parts do i need off the type r ..
what do i need to put back on it...
Old Feb 4, 2002 | 06:38 PM
JunCivic Hatch's Avatar
New User
Default Re: type r suspension on eg (NatuRaldisasteR)
Ok well, were all going to thing the same thing when you say you want to put your stock eg suspension back on the itr and make sure it rolls. Doesn't sound legit but anyway.
Grab the sway bar, lower control arms, brake knuckle hub assembly, shocks if you want. Anything you take from the ITR replace with your stock EG stuff.
If this car is legit and being parted out, do you have the ITR tranny for sale?
Old Feb 4, 2002 | 06:48 PM
IN VTEC's Avatar
You might as well take all the suspension pieces and anything with a rubber bushing in it...they're stiffer.
Old Feb 4, 2002 | 08:22 PM
peebrain's Avatar
Default Re: type r suspension on eg (IN VTEC)
the car is smashed on the passenger side, caved in the right door...so hard the door panel is cracked...anyway the car rolls and it needs to roll when im done...the complete drivetrain is there and will be for sale also, yes it will be legit, yes it will have all the #'s and yes the are spoken for at the moment...a few friends and i have all pitched in to buy this car, i got dibbs on the suspension for sure...maybe more...but for sure i can fit eg suspension????
rear also?? do i take the trailing arms and all brake lines or can i use mine...and can i use my eg struts since they are agx i wanna keep em...
Old Feb 4, 2002 | 09:13 PM
smp534's Avatar
New User
just get some steel braided lines.....no use in gettin another set of rubber hoses
Old Feb 19, 2002 | 11:06 PM
Reid's Avatar
Global Moderator
Default Re: type r suspension on eg (smp534)
Click the link in my sig.
SpoogenJay
Feb 28, 2006 03:43 PM
egb18c5
Dec 16, 2005 01:44 AM
onboost
Feb 1, 2005 06:37 PM
onboost
Feb 1, 2005 06:22 PM
