TDC.. crankshaft
Old Feb 8, 2002 | 12:06 PM
illusion's Avatar
Default TDC.. crankshaft
im about to perform a valve adjustment on my car tomorrow. according to the helms manual, i need to turn the crankshaft to TDC for each piston. after im done, the crankshaft needs to be retorqued to 181lb-ft.
is there a way to do this without using a socket on the crankshaft pulley? can i put the car in gear and merely push?
[Modified by illusion, 4:07 PM 2/8/2002]
Old Feb 8, 2002 | 12:25 PM
Jesse H's Avatar
Default Re: TDC.. crankshaft (illusion)
just use the bolt on the crank pulley. No way are you going to loosen it, I promise.
To loosen mine, I actually got the Honda tool to lock the pulley, with the attached ~2' long bar. Then I attached the socket/ratchet, and used a breaker bar about ~2' long. My heavier friend held on to the pulley lock while I bore down with my weight on the ratchet. I had to really get down on it to break it loose.
Old Feb 8, 2002 | 01:24 PM
fixhondas's Avatar
Default Re: TDC.. crankshaft (Jesse H)
I 100% agree with jesse
If you really want to though- remove your spark plugs and you can turn the crank using the P/S pulley nut. (19mm)
Old Feb 8, 2002 | 05:11 PM
illusion's Avatar
Default Re: TDC.. crankshaft (fixhondas)
thing is.. i dont have a torque wrench to retorque the pulley to 181lb-ft after im through. thats why i didnt want to do it.
Old Feb 8, 2002 | 07:04 PM
Mikey3000's Avatar
yeah what they said was true. there is no way in hell you will loosen that crank pulley bolt at ALL. so you won't have to retorque it. i could count about 1000 posts where people have asked for tricks to get that F*CK*N PIECE OF SH*T, D*CKLESS, F*CK SH*T off of there. sorry about the expletives. i just remembered how difficult it was for me to get it off.
[Modified by H22Turbo, 11:04 PM 2/8/2002]
Old Feb 8, 2002 | 09:58 PM
C-speed's Avatar
Did you look here?
http://www.c-speedracing.com/howto/v...lveadjust.html
Old Feb 9, 2002 | 05:56 AM
illusion's Avatar
Default Re: TDC.. crankshaft (G3-TEG)
yeah actually i have that site bookmarked. its great. thanks!
is it necessary to modify a 10mm wrench shown here? http://www.c-speedracing.com/howto/...cs/dsc00003.jpg
i was just reading this tutorial over as well as my helms manual one last time. i dont have the tappet tools so im gonna be using a screwdriver and wrench.
if i do have to modify the wrench like that, how would i do it? would it need to be heated and then bent? or will a regular open ended 10mm work?
[Modified by illusion, 10:57 AM 2/9/2002]
Old Feb 9, 2002 | 07:33 AM
dirtySOHC's's Avatar
yah you shouldnt need to retorque. because if those bolts arent the hardest things to get off then i dont know wat is.
BLKFLSH
Apr 10, 2011 01:54 PM
natebaur
May 9, 2009 05:09 PM
grngsr01
Oct 23, 2005 05:47 AM
EgSalad
22
Oct 7, 2005 05:03 PM
xrocket21
Jun 4, 2003 04:35 PM
