Should i get MSD?
Old Feb 3, 2002 | 06:15 AM
KevronsEG's Avatar
Default Should i get MSD?
i have d16z6 with zex cam, y8 intake manifold,ls throttle body and some basic bolt ons. I'm going to get zex nitrous but should i get the MSD and if so which one should i get.
Old Feb 3, 2002 | 09:37 AM
mannyman's Avatar
El Veterano de Sur Califas
Default Re: Should i get MSD? (CIV616)
yeah that would be a good idea, even though most people wouldnt agree. And you just need the MSD6a.
Old Feb 3, 2002 | 08:05 PM
Duck Sauce's Avatar
Default Re: Should i get MSD? (mannyman)
Personally, I don't think you really need it. But the MSD 6BTM is a good one to get. It'll pull timing when you're spraying and advance it back to normal when you're not on the bottle.
Old Feb 4, 2002 | 04:18 AM
Mista Bone's Avatar
D Tranny Guru
gonna spray? get the MSD 6AL
Use a MSD RPM pill 200 rpm lower than fuel cut on your ECU.
Old Feb 4, 2002 | 10:01 AM
rainforest's Avatar
Default Re: Should i get MSD? (B!6@_gOnEn!3sEcOnDs...)
yeah thats the 6al.
Old Feb 4, 2002 | 12:47 PM
Lt. Dan's Avatar
Default Re: Should i get MSD? (rainforest)
If you're going to spray, it's a good idea.. if not, it's not worth it...
Dan
Old Feb 4, 2002 | 01:01 PM
B18C-EJ1
Guest
Posts: n/a
Default Re: Should i get MSD? (Lt. Dan)
Dan
I'm with dan on this one.
The best MSD for spray is the Digital 6+, nothing else.
You get....
N20 timing retard
Revlimiter
2 stage revlimiter (launch control)
All in 1 neet little package.
Summit racing - $279.95 + ship!
Old Feb 4, 2002 | 06:22 PM
976's Avatar
976
New User
Default Re: Should i get MSD? (B18C-EJ1)
Digital is much better for nos induction. You might as well upgrade coil, duh? I recommend MSD Blaster 3. I like it, however the damn cap comes off everything I pull the wire, still works fine. Remember to take time to set the items you buy, be safe, ground, make sure you don't arch the wires, and mount them well, good luck! Reset ECU after, can't hurt!
PGT Driver
Aug 20, 2006 12:50 PM
omgwtfhaxnub
Feb 17, 2005 06:29 PM
CanadaCivicSIR
Jan 30, 2002 05:47 AM
auto-gs-king
Jan 28, 2002 12:29 AM
