Fix-A-Flat VS. Spare Tire
Old Feb 3, 2002 | 11:40 AM
ck279's Avatar
Default Fix-A-Flat VS. Spare Tire
I always thought for some reason that Fix-A-Flat and related products will indeed fix the flat, but afterwards you can't add more air or something. Is there a downside to using those products or can you inflate/deflate your tire as normal after using them???
Old Feb 3, 2002 | 01:22 PM
Padawan's Avatar
Darth ModerVader
Default Re: Fix-A-Flat VS. Spare Tire (ck279)
Fix-A-Flat definately doesn't fix all flats (something you don't want to learn the way I did). Adding more air shouldn't be a problem, but I wouldn't consider it a permanent repair.
Old Feb 4, 2002 | 07:18 AM
martini's Avatar
if you have nice rims, don't use the fix-a-flat. I learned that the hard way. then I found out it was my valve stem that was where the slow leak was...and it seeped out, and attached itself to my rim, and I just can not seem to get that poo poo off.
Old Feb 4, 2002 | 07:46 AM
Crazydave's Avatar
Default Re: Fix-A-Flat VS. Spare Tire (martini)
You should what fix a flat does to your nice alloy rims...
it eats the hell out of the inside of your rim..
makes taking the tire off the rim a B!?@#
and doesn't always work...
keep your spare and check it's pressure when you check the rest of your tires
Old Feb 4, 2002 | 08:12 AM
JeffS's Avatar
Every time I've ever needed a spare, fix-a-flat wouldn't have helped...
Old Feb 4, 2002 | 08:33 AM
SiR Kid's Avatar
New User
Default Re: Fix-A-Flat VS. Spare Tire (JeffS)
If you hit a pothole and bust the wheel, you're frucked with a nice shiny can of fix-a-flat in your hand
Carry a spare... Please?
Old Feb 4, 2002 | 08:45 AM
WuShu's Avatar
New User
Default Re: Fix-A-Flat VS. Spare Tire (SiR Kid)
fixa flat sucks! got a flat and put in some fixa flat, finally realized there was a huge hole in the tire, stuff got all over the rims and on my hands.
get a stealie and buy a cheap tire, keep it wiht you at all times.
Old Feb 4, 2002 | 12:33 PM
fixhondas's Avatar
Default Re: Fix-A-Flat VS. Spare Tire (HondaCRX)
Fix a flat is good for one thing- ruining tires- unless it is an emergency- don't use it.
Old Feb 4, 2002 | 12:50 PM
Lt. Dan's Avatar
Default Re: Fix-A-Flat VS. Spare Tire (fixhondas)
If you're going to use fix-a-flat, remember to drive straight to a gas station, deflate the tire again, and re-inflate with AIR... the gas that they use to pressurize the can is extremely flammable..... you wanna see a blow out? hehe... that'll really give you a "blow out"
Dan
Old Feb 4, 2002 | 12:53 PM
ck279's Avatar
Default Re: Fix-A-Flat VS. Spare Tire (Lt. Dan)
Thanks for the replies. I do carry my spare always. I thought that if there wasn't really a downside to Fix-A-Flat that I could save some weight and not carry the spare. Oh-well, no loss. Thanks again.
John 07
Mar 23, 2009 07:47 PM
vdub08
Jan 18, 2005 06:52 AM
Hate the Game
Apr 24, 2004 05:11 AM
Type Wah
Apr 3, 2003 08:52 PM
ck279
17
Feb 6, 2002 07:13 AM
