Cooling Fan
Old Feb 8, 2002 | 06:10 PM
oddcivic's Avatar
Default Cooling Fan
How come my fan for my radiator doesnt kick in when its hot anymore? help please.
more info: fan was tested and still run...
[Modified by oddcivic, 3:12 AM 2/9/2002]
Old Feb 8, 2002 | 06:15 PM
slowestcivicever's Avatar
Default Re: Cooling Fan (oddcivic)
Maybe your fan is bad...it happen to me on an accord...fan worked but didnt want to run when it was hot...help me out if im wrong honda-techs.
Old Feb 8, 2002 | 06:38 PM
FitCRX's Avatar
Default Re: Cooling Fan (slowestcivicever)
Possiblity your fan temp switch? or the relay I don't know if that link worked....but go to hybrid >>"where the hell is the knock sensor" couple pages back. It has a picture...the picture with the Blocked sensor saying "knock sensor" is the one that you want to look at. If you look closely ...beside the oil filter..theres a white sensor....above that sensor(black thing with two prongs) is the fan temp switch. Pull the rubber cover off of yours....cut the car on...connect the two wires going to the sensor together. Fan should cut on if it works. If it doesn't work...chech relays. https://honda-tech.com/zerothread?id=124890
[Modified by FitCRX, 3:39 AM 2/9/2002]
[Modified by FitCRX, 3:41 AM 2/9/2002]
peteyparado
May 12, 2013 08:43 AM
tunerEF9
Apr 30, 2010 11:12 AM
motormike40
Apr 1, 2007 03:55 PM
SpoonFedEF7
May 19, 2003 08:53 PM
SiViK-R
Jan 24, 2002 02:02 PM
