MSD Ignition box and coil mounting location?
Old Feb 5, 2002 | 02:50 PM
GruvyTune's Avatar
New User
Default MSD Ignition box and coil mounting location?
Where the hell is a good spot to mount these? There is basically no room left in the engine compartment.
If i squeeze it into the firewall behind the intake manifold, how do you mount the rubber feet? If you drill a hole, how do you get a nut on the bolt to fasten them? Or should I forget the shock absorbing feet and just sheet metal screw the stuff down?
Old Feb 5, 2002 | 05:10 PM
flymecourageously's Avatar
New User
Default Re: MSD Ignition box and coil mounting location? (GruvyTune)
fasten the box to the fire wall and the coil on the wheel .and use self tapping screws
Old Feb 6, 2002 | 06:25 AM
HPilot's Avatar
New User
Hey Torin....I know what you mean by no more space. I mounted my MSD box behind my console inside the car, then ran the wires thru the firewall. There may or may not be space behind your console (under the dash). I already sent you an email on how to handle the coil.
Old Feb 6, 2002 | 08:13 AM
unFOB4U's Avatar
I have mine on my firewall, only attatched by 2 screws and I have the coil mounted to the plasic piece of my Battery cover on the side.
hatchinprogress
14
Oct 9, 2004 05:03 AM
Doug684
Feb 27, 2004 04:28 AM
tnsxsear1
10
Dec 3, 2003 06:31 AM
GruvyTune
Feb 6, 2002 02:43 AM
