Auto To Manual
Old Feb 4, 2002 | 10:21 AM
oddcivic's Avatar
Default Auto To Manual
I swapped a manual motor into my automatic civic and there are 2 hoses that comes from the radiator that use to go to the automatic's tranny...what do i do with these two hoses becuase i cant plug it in on the manaul tranny.
Old Feb 4, 2002 | 10:49 AM
SoloSol's Avatar
Default Re: Auto To Manual (oddcivic)
If I remember correctly just remove them, and it will be fine. It will not leak. Someone correct me if I'm wrong its been a while.
Old Feb 4, 2002 | 10:55 AM
sgT's Avatar
sgT
Default Re: Auto To Manual (SoloSol)
tranmission cooler.
just remove the hoses and drain the remaining fluid,
Old Feb 6, 2002 | 04:49 AM
oddcivic's Avatar
Default Re: Auto To Manual (sgT)
Is it safe to not have a transmission cooler?
Old Feb 6, 2002 | 06:31 AM
BlackAxis's Avatar
It's safe becuase a manual tranny doesn't heat up like a propane space heater like a automatic one does.
Old Feb 6, 2002 | 06:44 AM
Safir's Avatar
Default Re: Auto To Manual (BlackAxis)
I was planning to use that portion of the radiator as an oil cooler on mine.
Old Feb 6, 2002 | 07:45 AM
garagespecial
Guest
Posts: n/a
Default Re: Auto To Manual (Safir)
i just cut my hoses off short....too lazy to pull um off, poo poo was too hard .....yea yea wesk sauce
Old Feb 7, 2002 | 01:35 AM
oddcivic's Avatar
Default Re: Auto To Manual (garagespecial)
ok
Old Feb 7, 2002 | 08:08 AM
acura_typer's Avatar
Banned
I *WOULD NOT* use that small line for an oil cooler. It will not carry enough oil to supply the engine.
The only way I would use it to cool oil was if I had a turbo. Run the return line through there first, then back to the oil pan. But that is the ONLY way.
My oil filter/cooler setup uses 1/2 line.
Old Feb 7, 2002 | 12:22 PM
oddcivic's Avatar
Default Re: Auto To Manual (acura_typer)
i was thinking of that also
shawn_crx
Jul 24, 2009 02:57 PM
realblag
Aug 26, 2003 06:48 PM
leprechan117
Apr 27, 2003 06:33 AM
AGPSuperstar
Mar 11, 2003 11:56 PM
GZERO
Dec 29, 2002 10:32 AM
