knocking noise after strut/coilover install??
Old Feb 5, 2002 | 09:47 AM
ArchAngel Sabastian's Avatar
New User
Default knocking noise after strut/coilover install??
we just installed the front two struts and coilovers on a firends 96 accord
(kyb agx, obx coilovers)
after the install there is a strange knocking noise that we can hear
so basically whenever there is a bump or dip in the road we hear the noise
anyone any idea?
Old Feb 5, 2002 | 09:57 AM
ForcedAccord's Avatar
Texas B*tch!
Default Re: knocking noise after strut/coilover install?? (Sabastian)
Hmm........ are all the bolts tight?
Is the strut bolted firmly on the car?
Did you put the bushings/washers in the right order for the stabilizer bar?
Is the spring secure within the strut?
Is everything aligned right, pinch bolt, through bolt, etc..?
Hmmm
Old Feb 5, 2002 | 10:06 AM
New User
Default Re: knocking noise after strut/coilover install?? (ForcedAccord)
will check...
Old Feb 5, 2002 | 10:16 AM
AE86's Avatar
something is loose for sure... double check everything and make sure everythings tight. Also use an impact gun to tighten the nut on the shock.
Old Feb 5, 2002 | 11:14 AM
Texas B*tch!
Default Re: knocking noise after strut/coilover install?? (AE86)
You don't need that, just tighten it the best you can, that should suffice. Just make sure the spring still isn't loose within the strut.
Old Feb 5, 2002 | 11:25 AM
HaUTSaauce's Avatar
New User
dont sound good man
Old Feb 5, 2002 | 11:37 AM
New User
Default Re: knocking noise after strut/coilover install?? (HaUTSaauce)
the nuts that go on the strut themselves were lose, this stoped the knocking.
? when tightening these nuts after so far the strut "top or whatever its called"
the piece that has the adjutable dial on top of it anyway that starts to spin along with the nut did i miss a washer or something?? or is it tighten enough?
Old Feb 5, 2002 | 11:51 AM
Texas B*tch!
Tighten is as much as you can w/ out stripping the SOB. Hehe. You remember having to pop em pretty good before they would come off? Make them that tight again.
colton1808
Feb 28, 2018 01:24 PM
topshot-rhit
Jun 23, 2010 06:57 AM
holdenw172
Honda Civic (2001 - 2005)
10
Dec 28, 2008 12:05 PM
greenwar
Apr 26, 2008 06:11 PM
Slow&Furious
Nov 15, 2001 05:42 PM
