Strut Tower Brace Question
Old Mar 6, 2003 | 01:03 PM
Kronic's Avatar
Default Strut Tower Brace Question
1. brace bolts up to some holes drilled into the tower.
2. brace is connected to the bolts that hold the strut to the tower.
witch one is better?
pros/cons
i used the search but no luck.
thanks
Old Mar 6, 2003 | 01:16 PM
joe_bocc's Avatar
Default Re: Strut Tower Brace Question (Kronic)
I would go with option 2. solidly mounted to the top of the strut tower.
Old Mar 6, 2003 | 01:50 PM
Kronic's Avatar
Default Re: Strut Tower Brace Question (joe_bocc)
most of the braces ive come across. bolt up to holes drilled in the tower. (option 1)
i just saw one that bolted to the struts and the guy claims its better. i belive his would put more stress on the struts but, i dont really know for sure.
Old Mar 6, 2003 | 01:55 PM
Nate B's Avatar
Neither yields any advantage, all it's doing is preventing flex in the chassis, whether it's mounted to the struts or the bolts already welded to the frame does not matter. What does matter is the design of the bar. A common rectangular bar is more prone to crease under stress rather than a tubular bar that can handle much more stress and is less likely to flex or crease. Hope that helps
Old Mar 6, 2003 | 02:01 PM
genetsang's Avatar
Default Re: Strut Tower Brace Question (OG Bizzle)
.... so what you are trying to saying DC sports is no good... on the other hand.. Ractive is better with its tubular design?
DC it is.. cus thats what i got...
Old Mar 6, 2003 | 02:35 PM
silverCRXTC's Avatar
Default Re: Strut Tower Brace Question (genetsang)
idk drilling scares me, i would go with a strut tower mount one, i got the skunk2 one coming so we'll see
Old Mar 7, 2003 | 10:42 AM
Kronic's Avatar
Default Re: Strut Tower Brace Question (silverCRXTC)
please correct me if im wrong but, i think unless the holes have already been drilled. you will have to drill the towers to fit skunk2s strut brace.
Outlaw-Hondaz
Jan 27, 2010 01:52 PM
shutta
Jan 6, 2006 01:10 PM
vaajboy
Sep 8, 2004 06:58 AM
nc-rsx-s
Aug 17, 2002 03:51 PM
revhrdls
Aug 4, 2001 03:51 AM
