Burning Oil ?
this is a huge concern. you probably burnt your rings which would explain that low compression your motor has. i would suggest a total re-build or a new motor. you'd probably be faster with a nice fresh d15.
If your motor is know to burn oil it's a <U>GOOD</U> idea to check it regularly. If not your motor will die a slow death eventaully leaving you hybridless or even worse stranded. Betta get a cell phone if you don't have one.
Do an oil consumption test to determine exactly how much oil you are actually burning. Top off the oil to the full line, and check your oil regularly, keeping track of how many miles it takes to burn a quart of oil. Sounds like you are burning a substantial amount, you may be looking at valve guide seals, rings, or even a bore job with oversize pistons and rings. Also make sure to check for any oil leaks. If you are burning the oil, you should see blue smoke when you rev the engine up. Good luck.
damn grizz too bad your odometer doesn't work either....looks like that test is out the window...haha...i'm just messin with ya man...we'll see who has the braggin rights after fri. night at the track
buring excessive amounts of oil like that is not a good sign.
rings may be worn terribly, valveguide seals also. maybe a major oil leak that you didn't see. always make sure you have enough oil in the motor, even if it means checking the level a couple times a week. if you drive hard and long then it's gonna disappear quickly.
mate samething happened in my R,
Am curently rebuilding the engine... GEt it checked out dude. I'm 7K in debt!!!
I need new pistons and re-grind crank.. And to add insult to injury, my ITR only has 14000 kms
Jansen
Jansen
