2000 Gs-r ECU Immobilizer????
Old Mar 7, 2003 | 05:56 AM
1hottEG6's Avatar
Default 2000 Gs-r ECU Immobilizer????
What is this immobilizer feature, I work at Honda and have connection to local Acura Store before i go being a pain in the *** over there, can this 2k ecu be reset to work in a different car or...?? ANy help would be great thanks
Im puttin the ECU in a 99 hatch will it even work?
Old Mar 7, 2003 | 06:10 AM
JimBlake's Avatar
Default Re: 2000 Gs-r ECU Immobilizer???? (B20eg-T)
There's a small chip inside each key. The ECU recognizes 'its own' keys, & won't start without them. There has to be a way of programming new keys to the ECU, but I don't know the details.
For our '01 Saab, you have to have all your keys together at once. Dealer plugs in a TECH-II computer, & tells it to recognize your keys. If you left one at home, it won't work any more. I suppose Hondas are roughly the same.
Old Mar 7, 2003 | 06:54 AM
1hottEG6's Avatar
Default Re: 2000 Gs-r ECU Immobilizer???? (JimBlake)
I guess i will just call over there and see what they have to say thanks for the info
Old Mar 7, 2003 | 07:28 AM
slomofo's Avatar
GDD Member
Can you post what you find out? I bought a junkyard OBD2 P72 and just found out about the immobilizer a few days ago.
Old Mar 7, 2003 | 07:42 AM
1hottEG6's Avatar
Default Re: 2000 Gs-r ECU Immobilizer???? (slomofo)
sure man, im gonna call in a lil bit
Old Mar 7, 2003 | 01:03 PM
JimBlake's Avatar
Lots of discussion about this on SaabNet.com with the basic idea that some dealers do it for free or real cheap, some dealers are jerks. Imagine that! It takes about 5 minutes to do it.
So you probably ought to call your dealer for their answer.
Tech-II is kind of like the Honda PGM-FI tester thing... It reads OBD-2 codes just like the guy at AutoZoned, but it also programs all the other stuff in the car like how the locks work. Some independant mechanics have Tech-II devices, so its not exactly a dealer monopoly.
Old Mar 7, 2003 | 03:57 PM
7PSI CRX's Avatar
I've "heard" Locash can remove the immobilizer feature from these ECUs.
http://www.locashracing.com/
Old Mar 7, 2003 | 04:29 PM
Wes d's Avatar
Default Re: 2000 Gs-r ECU Immobilizer???? (7PSI CRX)
What year did they start using the imobilizers on??
LAEGER525R
Feb 13, 2010 02:58 PM
AK_CRX
Mar 14, 2008 05:38 PM
PolySquared
Nov 28, 2003 07:48 PM
cr8zygsr
Oct 29, 2003 08:49 PM
