Use water temp gauge for intake temp
Old Jan 8, 2004 | 02:05 PM
Del_Slowest's Avatar
Default Use water temp gauge for intake temp
Intake temp gauges are so expensive so i was thinking ...can i get a water temp gauge and hook it up to my stock intake air temp gauge? If not is there some other gauge that would work?
Also, can i use a water temp sender unit for the intake temp and just weld it into my charge pipe?
Old Jan 8, 2004 | 03:22 PM
tjbizzo's Avatar
Screw you guys, I'm... going... home.
Default Re: Use water temp gauge for intake temp (Del_Slowest)
I think it would be very slow to react to temp changes and unless you had very high intake temps, i.e. under high boost and no/poor intercooling, it would always read at the low end of the gauge. How about an indoor/outdoor thermometer from Home Depot or a hardware store? A lot of the indoor/outdoor thermometers, the kind that you mount on a door or window frame, use a mechanical sensor on a thin tube that you place outside. Of course it's best to buy something that is really intended for this. Look in http://www.mcmaster.com/ or http://www.mscdirect.com/ for thermometers and thermocouples. They have several that run on AA batteries and even have memory and alarm for about $30. Your mileage may vary.
Old Jan 8, 2004 | 05:37 PM
Default Re: Use water temp gauge for intake temp (tjbizzo)
i looked on mcmaster.com and they didn't have any cheap ones ie 50 bucks or less. there has to be a gauge that i can just wire in...
Old Jan 8, 2004 | 06:53 PM
tjbizzo's Avatar
sorry, I was only looking at my msc catalog. try msc part# 56472707, 05834619, 05834684, 05834692, 05834700, 05834718, 05834726, 56472624, and 01232198.
Old Jan 8, 2004 | 11:47 PM
dfoxengr's Avatar
get a cheap battery powered inside outside thermometer (if youre not just wanting this to look pretty, and stick it in the glove box. wire the sensor to the TB or intake
boostedb20z
May 8, 2011 09:48 PM
innes887
Jun 13, 2007 11:12 AM
flip1199
Aug 20, 2005 04:39 AM
92sleepR
Jun 20, 2002 08:12 AM
