Plugging oil squirters, what thread pitch?
b18c1 block...
I'd like to have the proper pitch before I go shopping for plugs. It could be metric fine 8mm x .75 but I'm not sure. If there is someone on here that has done this where did you buy plugs?
Thank you!
Thank you!
The easiest way to do this is cut the nozzle off and weld the hole shut. And with the nozzle shut you can still use the bolt and base, or what ever you call what is left of the nozzle. I know alot of racers that do this.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Earl »</TD></TR><TR><TD CLASS="quote">The squirter bolts are 8mm with .75 pitch. If you find a source for this size of bolt, let me know. The bolt could not be longer than .5 inch. It would be much quicker to install these bolts than to tap and plug the oil squirter hole. That way you could also return the oil squirters to the block, if desired.
Earl</TD></TR></TABLE>
If you dont plan on using them again, you can just drill and tap the original holes to 1/8" npt. Then install small plugs. That is what I did.
Thanks teggie.. looks good.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicvteckid »</TD></TR><TR><TD CLASS="quote">What dose pluging the oil squirters do for the engine?</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=337110
Read that thread
Read that thread
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Teggie »</TD></TR><TR><TD CLASS="quote">If you dont plan on using them again, you can just drill and tap the original holes to 1/8" npt. Then install small plugs. That is what I did.
Where can you get these plugs?
</TD></TR></TABLE>Where can you get these plugs?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by servion »</TD></TR><TR><TD CLASS="quote">
Where can you get these plugs?</TD></TR></TABLE>
Thay are just 1/8" NPT plugs. Try Jegs, Summit, etc...
totsie7944
Apr 3, 2008 08:27 PM
lando griffin
Honda Civic (2006 - 2015)
Oct 1, 2007 04:32 PM
MeanGreenEG9
Aug 2, 2004 10:19 AM
