What nitrous kit to get?
Old May 11, 2003 | 10:31 PM
STEV3-O's Avatar
Default What nitrous kit to get?
im planning on running a little nitrous on my 95 cx hatch with b16 with intake and headers, everything else stock. What kit should i run, any suggestions. also i herd zex is the simple kit. how does it work, like when time to run the nitrous. i dont plan on going anything over 75 shot, i only want it for when going to the track. thanks.
Old May 12, 2003 | 01:20 AM
wicked2night's Avatar
Default Re: What nitrous kit to get? (sleepingeg6)
My choice would be nothing more than 50shot on stock internals.
Old May 12, 2003 | 01:23 AM
StreetRacnGsR
Guest
Posts: n/a
Default Re: What nitrous kit to get? (wicked2night)
Hey i ran 125 shot to my b16a2 99-00 swap i had with stock internals. I ran it only on weekends also for your question I would go with Zex (if your cheap) but i perfer Nitrous Express or NOS Direct port system.
Old May 12, 2003 | 06:50 AM
Timmay's Avatar
Default Re: What nitrous kit to get? (StreetRacnGsR)
i really like Nitrous express wet kit, you could do a 70 shot with timing retarded 2 degrees, colder plugs and premium fuel, dont spray under 3k rpms and dont hit rev limiter while spraying!!!!
i hate ZEX
Old May 12, 2003 | 07:40 AM
baldylox's Avatar
my setup is as follows:
99 civic SI I/H/E
Stock internals
NX EFI Wet Kit/50-75 shot
Genx upgrades
MSD Digi6+ w/Cap/coil
NGK plugs/wires
MSD window switch...saved my 5 times
Old May 12, 2003 | 08:30 AM
RyanEJ8's Avatar
Default Re: What nitrous kit to get? (1slow4door)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1slow4door &raquo;</TD></TR><TR><TD CLASS="quote">i hate ZEX</TD></TR></TABLE>
Yeah but who's going to listen to someone who's been a member for 12 days and has 21 posts. Zex is one of the best kits out there for the price. Read the info I posted in this thread. https://honda-tech.com/zerothread?id=502193
Old May 12, 2003 | 09:41 AM
2KWK4U's Avatar
Default Re: What nitrous kit to get? (RyanCivic2000)
Like the guy above me said, who is gonna listen to a newbie, but I do not like the Zex kit. I would reccomend the NOS dry kit, or a fogger kit.
Old May 12, 2003 | 10:00 AM
RyanEJ8's Avatar
Default Re: What nitrous kit to get? (2KWK4U)
ZEX dry kit is definately better than a NOS dry kit. If you're going to go NOS or NX spend the extra money for the wet kit, if not ZEX all the way. Easier to install, and the kit is more complete than the NOS.
Old May 12, 2003 | 12:15 PM
whatVTEC's Avatar
i say go with a NX wet kit.
buddy had both, zex and NX and he liked the NX
I'm running the Noszle kit by NOS and I really like that kit, but wouldn't reccomend on a stock motor.
Old May 12, 2003 | 12:20 PM
dfoxengr's Avatar
NX 75 shot efi setup
Old May 12, 2003 | 02:21 PM
STEV3-O's Avatar
Default Re: What nitrous kit to get? (hybridvteceg)
thanks guys really appreciate it. any info on how the zex kit works. i like it cause of the simple setup up. price is not a prob for me as i can get nx for about 300 as well as the zex for the same price. i just was thinking more zex as it looks easy for me to install.
Old May 15, 2003 | 12:44 PM
Timmay's Avatar
ZEX isnt that much easier to put on than NX IMO but get what you feel works
Old May 15, 2003 | 01:04 PM
raene's Avatar
How it works is simple...
Install a nozzle into your air intake. Nitrous connects to the master 'brain', as well as fuel return. As the nitrous passes through the brain, it pressures on a diaphragm touching the fuel return line, so the line is compressed so less fuel can pass through the return line. Hence, higher fuel pressures, hence, more fuel. The larger the hit, the more the line is compressed and the more fuel you get. The same goes for an emptying bottle - as the nitrous runs out, the line is compressed less so you get less fuel. Pretty simple IMO.
Old May 15, 2003 | 01:39 PM
whoa its len 2's Avatar
Default Re: What nitrous kit to get? (raene)
ZEX has a wet kit kit now.
Old May 15, 2003 | 03:09 PM
BerlinaAP2's Avatar
Default Re: What nitrous kit to get? (whoaitslen2)
NX i heard is real easy to use
Old May 15, 2003 | 03:44 PM
apexi's Avatar
I'm running VENNOM 1000 Very happy with the performance Easy installation. Turn it on and stomp on the GAS. Makes the 1.7 L in my CIVIC eats Mustang GTs. Prelude SI, Hybrid B18Cs, CIVIC SI. BMW 530I. I'm very happy with it. Many may disagree but they don't own one.
Old May 15, 2003 | 04:04 PM
orange.honda's Avatar
Default Re: (civic7)
i like my nos kit. i think it in itself is pretty simple to intsall and use. also since my kit came with 2 solenoids i only run one and made the other into a purge valve.
Old May 15, 2003 | 06:02 PM
StreetRacnGsR
Guest
Posts: n/a
Well to all of you i aint a newb i have been on this website for almost a year. I have been using Nitrous Systems for 2 years now. as long as u know how to use NOS the proper way u can use 150 Shot on stock engine. But i do not recommend it unless your know how to use NOS..
Old May 15, 2003 | 07:05 PM
9200RPM's Avatar
I was going to do a zex kit, in fact i bought one until i read about the NXL kit from nitrous express......Check it out....the only draw back is that it retails for $1280....but you can find it cheaper, I have...
Old May 15, 2003 | 11:26 PM
STEV3-O's Avatar
Default Re: What nitrous kit to get? (TurboB16aEG)
thanks guys, really appreciate it, what u guys think ill run with a 55 shot of zex, i got 95 cx, aem short ram intake, dc 4-1 headers, and 2 1/4 piping. full interior.
Old May 16, 2003 | 10:25 AM
evo's Avatar
evo
New User
Where do you guys mount the ZEX brain, in the engine bay or under the seat??
Old May 16, 2003 | 11:56 AM
RyanEJ8's Avatar
Default Re: What nitrous kit to get? (evo)
I mounted mine in the engine bay. You should be able to see the little purple box in my avatar right above the intake manifold.
Old May 16, 2003 | 12:05 PM
evo's Avatar
evo
New User
how did you mount it, drilled to the fire wall or?? Cuz I c't find any flat surface to fit the box.
Old May 17, 2003 | 06:57 PM
civicsitek GanGsTa's Avatar
I mounted my kit in the passanger footwell area up underneath a little bit....very stealth. No one knows you have a kit if you plum the nitrous on the underside of the intake and cover every hose with flex loom
Old May 18, 2003 | 03:30 AM
97hb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 &raquo;</TD></TR><TR><TD CLASS="quote">I mounted mine in the engine bay. You should be able to see the little purple box in my avatar right above the intake manifold.</TD></TR></TABLE>
Thats exactly where I mounted mine , its like the perfect location.
