Need info on injectors
Old May 8, 2003 | 01:09 PM
toooslow's Avatar
Default Need info on injectors
I was wondering if someone could enlighten me on which injectors from other cars could i use for my 95 gsr. I heard that dsm injectors would work. How many cc's do the stock gsr injectors run at, 220, 240? What would happen if you put 400cc injectors in a near stock gsr, i will be going full turbo soon?
Old May 8, 2003 | 01:23 PM
joe_bocc's Avatar
Default Re: Need info on injectors (whiteinteg95)
stock GSR injectors run at 240 cc/min. I think 5th gen Prelude injectors will work, they are 290 cc/min. The DSM are usable from what i understand. you need the injectors, clips, resistor box, ?. I not toally sure
Old May 8, 2003 | 04:15 PM
sgT's Avatar
sgT
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whiteinteg95 &raquo;</TD></TR><TR><TD CLASS="quote">What would happen if you put 400cc injectors in a near stock gsr, i will be going full turbo soon?</TD></TR></TABLE>
It would barely run and possibly ruin the motor.
Old May 8, 2003 | 04:25 PM
toooslow's Avatar
could you tell me more about injectors. Are the stock injectors sufficient? What kind of mods could stock gsr injectors handle? Is there a difference between obd1 and obd2 injectors?
Modified by whiteinteg95 at 5:31 PM 5/9/2003
Modified by whiteinteg95 at 5:47 PM 5/9/2003
Old May 9, 2003 | 08:32 AM
toooslow's Avatar
anyone else???
Old May 9, 2003 | 09:29 AM
joe_bocc's Avatar
Default Re: (whiteinteg95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whiteinteg95 &raquo;</TD></TR><TR><TD CLASS="quote">could you tell me more about injectors. Are the stock injectors sufficient? What kind of mods could stock gsr injectors handle? Is there a difference between obd1 and obd2 injectors?</TD></TR></TABLE>
What are your plans. The stock injectora could pretty much handle most bolt-ons as well as a a basic turbo set-up. Once you go beyond that, upgraded injectors are pretty much a necessity.
LILSOWEK
Oct 18, 2006 04:08 PM
96SR-V
Apr 21, 2003 03:58 PM
1.8T_EG
Sep 7, 2002 09:30 PM
