where to wire the electrical water pump?
Old Jan 9, 2005 | 07:01 PM
viet's Avatar
Default where to wire the electrical water pump?
i have Aeb's electrical water pump for GSR..don't know where to wire it to.. any ideas?
Old Jan 9, 2005 | 09:55 PM
Kendall's Avatar
Did you call AEBS for a wiring recommendation?
Old Jan 9, 2005 | 10:51 PM
viet's Avatar
Default Re: (Kendall)
the guy barely spoke english and he told me to wire it to my ignition?
Old Jan 10, 2005 | 05:01 AM
EE_Chris's Avatar
Default Re: (viet)
How many wires?
If its just a straight up power and ground, then the guy gave you the right 'directions'. You need to use a relay to switch the water pump on/off but you need to use an ignition signal to turn the relay on.
Old Jan 10, 2005 | 05:16 AM
viet's Avatar
Default Re: (EE_Chris)
yea its power adn ground
Old Jan 10, 2005 | 09:01 AM
b18bturbo's Avatar
Default Re: (viet)
it dpeends on hwo you are setting it up. Is this for a drag car or street/strip car.
you have two options to wire it up. Manual wire it up off a switch or wire it off ignition on position
i prefer the first method utilizing a relay setup. with the electric pumps the cars tend to overcool themselves
Old Jan 10, 2005 | 10:05 AM
viet's Avatar
Default Re: (b18bturbo)
its for street but i think i'm gona go with the relay to the ignition setup thanks guys
Old Jan 10, 2005 | 11:03 AM
b18bturbo's Avatar
Default Re: (viet)
i would not reccommend running it on a street car. They are intented for mainly drag racing setups. I would just buy a factory water pump
Old Jan 10, 2005 | 08:06 PM
viet's Avatar
my frend ran it on his car..it was fine..but he just forgot how to wire it back up..
Old Jan 13, 2005 | 01:10 PM
h22 civic's Avatar
Default Re: (viet)
wire it to a adjustable thermostat switch but also put a bypass on it so you can turn it on when you want for instance after you manke a pass and want to shut the car down and leave the pump on its also a good idea to wire your fan in sync with it
Old Jan 22, 2005 | 09:05 PM
viet's Avatar
Default Re: (h22 civic)
ok i wired it to the ignition so wen i turn it on the water pump is on..but when i drive...it cools it all the way down to cold...so i don't kno wat to do now...any ideas? when i'm parked it'll stay warm but when i drive it cools and the heater goes cold also... someone help! lol
Old Jan 23, 2005 | 08:18 PM
suspendedHatch's Avatar
Default Re: (viet)
Is the thermostat even present? Check to make sure its not stuck open (boil it in a pot and see if it changes) or if it has big holes drilled into it. When you install an EWP you're supposed to drill a small hole into your thermostat but not too big or it over cools.
Don't wire the fan and the EWP together on a street car.
Civic Si Kid
Audio / Security / Video
May 17, 2009 12:26 PM
sCeRaXn
Sep 21, 2003 03:39 PM
sCeRaXn
Sep 13, 2003 12:14 PM
ridnmyhonda
Feb 13, 2003 04:23 PM
