d16y7 block w/y8 vtec head
Old Jan 20, 2005 | 02:51 AM
sheissrx's Avatar
Default d16y7 block w/y8 vtec head
Anyone know what needs to be done to put a y8 head on my y7 block, other than wiring? I was reading an ls/vtec thread, it showed an oil line going from where the oil flter mates the block to the head. Yes, bseries is different, I know.
For non-vtec d-series I've heard/read one could just slap it on and wire it . A y8 hg is needed too, right(for the vtec solenoid passage)? I need some help, no flaming please ( i searched)
Thanks.
Old Jan 20, 2005 | 05:19 AM
LilLowEK's Avatar
Default Re: d16y7 block w/y8 vtec head (sheissrx)
Sure, click the following link. It's a swap I did, and I made a massive write up on it.
http://www.jdmuniverse.com/for...32971
Jeremy
Old Jan 20, 2005 | 08:16 AM
sheissrx's Avatar
Default Re: d16y7 block w/y8 vtec head (LilLowEK)
I don't know man. That guy doesn't seem like he was doing it right. I didn't have to take off the crank pulley when I took of the the Timing belt... but thanks. Anyone else know?
Old Jan 20, 2005 | 08:27 AM
LilLowEK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sheissrx &raquo;</TD></TR><TR><TD CLASS="quote">I don't know man. That guy doesn't seem like he was doing it right. I didn't have to take off the crank pulley when I took of the the Timing belt... but thanks. Anyone else know?</TD></TR></TABLE>
Umm, I did that write up myself. It doesn't seem like I know what I'm doing on the swap?
Find a better write up and show it to me.
snatch's Avatar
Search for 'd16y7 mini me'. I found 30 some results. There are tons of write-ups about doing a mini-me.
Old Jan 20, 2005 | 08:37 AM
LilLowEK's Avatar
Btw, can you tell me how you take the timing belt off?
I couldn't find a way to get the bottom of the timing belt cover off w/ out remove the crank pulley.
You can simply hit the timing belt adjustment and slip it off the cam gear if your not replacing it. However I replaced mine.
Old Jan 21, 2005 | 05:44 AM
sheissrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LilLowEK &raquo;</TD></TR><TR><TD CLASS="quote">
You can simply hit the timing belt adjustment and slip it off the cam gear if your not replacing it. However I replaced mine. </TD></TR></TABLE>
Sorry dude, I didn't mean anything by it, but yeah..I'm not replacing the timing belt. Thanks. As for searching, I didn't thinkit would be called mini-me because it's not 1.5. thanks HELLUVALOT though .
Old Jan 21, 2005 | 05:52 AM
LilLowEK's Avatar
Sorry dude, I didn't mean anything by it, but yeah..I'm not replacing the timing belt. Thanks. As for searching, I didn't thinkit would be called mini-me because it's not 1.5. thanks HELLUVALOT though . </TD></TR></TABLE>
It's cool. Like I said, just losen the timing adjustment, and you should have enough slcak to slip the belt off.
Hope the write up helps.
Jeremy
Old Jan 21, 2005 | 06:12 AM
sheissrx's Avatar
so you can use the same hoses, right... or will they be kinked. Everything should pop off and pop on right, (hoses-wise)? that's the impression that I get.
Old Jan 21, 2005 | 06:22 AM
LilLowEK's Avatar
Hoses will work fine.
If you use the y8 IACV, you will need to rewire it. Also, vtec will need wired.
All the information is in the write up I made.
Hatzboy11
May 13, 2015 05:12 AM
ZCcivicBOI
Nov 23, 2007 06:41 PM
96electronH
Oct 1, 2007 08:13 AM
john256
Aug 6, 2007 09:18 PM
