Differences in B-Series Oil Pumps?
Compare an ITR oil pump and an LS oil pump. What physically makes the VTEC oil pumps better than the non-VTEC oil pumps? Just the spring thats on the inside that controls oil flow? Or is there something else?
The VTEC oil pumps are the same. There are only 2 types of B series oil pumps, OBD2 and non OBD2. The OBD2 have a mount for the crank fluctuation sensor, that is the only difference.
The oil pressure is not determined by the pump, but the pressure relief spring in the block, as you mentioned.
I thought the spring was in the pump itself. So basically what i'm asking is, could I use the spring from an itr pump in an ls pump to make it function like an itr pump?
Here is your question:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onezexycrx »</TD></TR><TR><TD CLASS="quote">I thought the spring was in the pump itself. So basically what i'm asking is, could I use the spring from an itr pump in an ls pump to make it function like an itr pump?</TD></TR></TABLE>
Here is your answer:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 »</TD></TR><TR><TD CLASS="quote">The VTEC oil pumps are the same. There are only 2 types of B series oil pumps, OBD2 and non OBD2. The OBD2 have a mount for the crank fluctuation sensor, that is the only difference.
The oil pressure is not determined by the pump, but the pressure relief spring in the block, as you mentioned.</TD></TR></TABLE>
VTEC/Non-VTEC has the same pump.
but as mentioned in the above post, the spring is not in the block. it is in the pump iteself. So my question is "Are the pressure springs in B-Series oil pumps interchangeable?"
The part numbers for the Relief Valve and Relief Valve Spring are the same for all B-Series oil pumps. So what makes a VTEC oil pump different from a non-VTEC one?
YES that is all you have to do.. is swap the washer... witch increases the oil pressure... from 60 to 90 ..
bseries, comparison, differences, differnces, diffrence, flow, honda, oil, pump, pumps, samr, series
