Would a bad main relay cause surging at part throttle?
Old May 16, 2005 | 03:27 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Default Would a bad main relay cause surging at part throttle?
I believe my car has a bad main relay (hard to start when warm) but it has also developed an issue of surging under part throttle while driving. Basically if you let off the throttle a bit and go to reapply it you have to almost fully open the throttle before the engine will cut back on. Under higher loads it runs smooth as silk and full throttle is not a problem but driving around town can be a jerky experience. The problem does not occur consisently.
Could this also be a symptom of a bad main relay?
Old Jul 6, 2005 | 11:37 PM
NocsCtr's Avatar
Default Re: Would a bad main relay cause surging at part throttle? (ActiveAero)
that sounds like something that happened to me a few times I really don't think it's a relay check ur vaccum lines sounds like u have a huge vaccum leak that or ur map sensor took a ****. check the vaccum line going from the fuel regulator to the intake manifold that hose right there has caused that problem for me a few times just check all ur vaccum lines make sure they are all connected and seald properly an listen for leaks
coelcanth
Jun 26, 2019 02:27 PM
M2B4
Jun 28, 2008 07:32 AM
IMHARD2
Jun 24, 2008 02:43 PM
jakscivic
Oct 4, 2006 08:41 PM
DeviousCTR
Jun 28, 2006 03:43 PM
