countershaft and mainshaft??
Old May 20, 2005 | 09:29 PM
honda011's Avatar
Default countershaft and mainshaft??
what is the diffrence between them ,becuase im looking to replace my second gear and i don't know the diffrence... thankx 4 the help...
Old May 21, 2005 | 07:57 AM
h22 civic's Avatar
Default Re: countershaft and mainshaft?? (honda011)
im not fully understand ing your question but if your swaping gears for totally new ones (that are of a different ratio) you must change the counter and main shaft gears
Old May 21, 2005 | 10:46 AM
Dogginator's Avatar
Daisy... Daisy...
http://www.acuraparts247.com
Old May 21, 2005 | 04:19 PM
honda011's Avatar
Default Re: countershaft and mainshaft?? (Dogginator)
that is the site i was orginally looking at, i don't understand it... what im saying is my second gear grinds do to synchros, but i know grnding messes up the gear so i want to toally replace my gsr 2nd gear for a new gsr second gear...
Old May 21, 2005 | 04:36 PM
Dogginator's Avatar
Daisy... Daisy...
Transmission work is difficult to plan. You won't know what is bad until you open it and inspect the parts. On the contrary, you probably don't want to have your car down for two weeks while awaiting parts? If you start buying all of the possibly bad parts, you can wind up with a hefty bill.
Hopefully your gears are not damaged. Maybe your synchros are worn, but still have some service life. When is the last time that you changed the transmission fluid?
Old May 21, 2005 | 05:25 PM
86si's Avatar
if they are grinding just do the syncros, it takes alot to damage the gears ...more than just worn syncros
Old May 21, 2005 | 05:54 PM
honda011's Avatar
Default Re: countershaft and mainshaft?? (86si)
alright thanks guys.... i blew my shortblock a while ago so i had to get a new tranny since it was in gear, the only time 2nd grinds is at high rpm's (7-8) i guys ill try some gearspeed synchros hopefully the problem will be solved thankc again...
OH and i changed my fluid about 2 months ago because i needed a new seal....
Old May 21, 2005 | 06:54 PM
Dan GSR's Avatar
gearspeed syncro
syncro should always be replaced as a full sleeve set
Old May 21, 2005 | 06:58 PM
honda011's Avatar
Default Re: countershaft and mainshaft?? (Dan GSR)
full sleeve set???? whats wrong with gear-speed synchros???
http://www.acuraparts247.com/s...ch=no number 007 is what i need??
Old May 21, 2005 | 06:59 PM
Dan GSR's Avatar
its incomplete
Old May 21, 2005 | 07:01 PM
honda011's Avatar
is number 007 what i need?? http://www.acuraparts247.com/s...ch=no
Dan GSR's Avatar
yes
Old May 21, 2005 | 07:02 PM
honda011's Avatar
thank you..
Transmission & Drivetrain
Mar 17, 2010 06:14 PM
zachv365
Sep 4, 2009 02:32 PM
killerpenguin21
Mar 4, 2009 05:08 PM
turbo-crx
Nov 3, 2008 04:22 PM
arrojj
May 16, 2007 07:40 AM
