Need help ASAP, headgasket question!
Old Nov 27, 2005 | 05:45 PM
NACvicSi's Avatar
Default Need help ASAP, headgasket question!
Well I bought a head from G2hybrid off here. I put it on my car with a new cometic headgasket. G2hybrid said the head had low miles and was in perfect condition so I didn't think to check the valves. Well the car ran like pure crap and shot raw gas out like a champ. Checked my compression and my #2 cyl had horrible compression. Took the head off and found out it had some bent valves on the #2 cyl.
So here is my question. I only drove the car around the block and idled for about 15 min. The headgasket was a Cometic MLS gasket. Can I reuse this gasket or do I need to buy another one?
Old Nov 27, 2005 | 05:54 PM
Muckman's Avatar
Moderator in Chief
Default Re: Need help ASAP, headgasket question! (NACvicSi)
Your not supposed to reuse head gaskets once they've been crushed.
But in your case I would try to unless your boosted.
Old Nov 27, 2005 | 06:04 PM
NACvicSi's Avatar
Default Re: Need help ASAP, headgasket question! (Muckman)
heh, not boosted yet. It's running 10.5:1 c/r, will be boosting about 5-8 psi later though. I just hate buying another one. This it the 4th one I bought with this build, keep having problems.
Old Nov 27, 2005 | 06:06 PM
NACvicSi's Avatar
If I have to buy another one I'm going to buy OEM, $30 is a lot better than $85.
Old Nov 27, 2005 | 06:07 PM
Muckman's Avatar
Moderator in Chief
30 bucks?! must be a D series.
Old Nov 27, 2005 | 06:20 PM
NACvicSi's Avatar
lol you know it. D16Y8
Old Nov 27, 2005 | 06:32 PM
NACvicSi's Avatar
Ok next question. Autozone/Advanced gasket or OEM, whats the difference?
Old Nov 27, 2005 | 09:52 PM
tianporn's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">Your not supposed to reuse head gaskets once they've been crushed.</TD></TR></TABLE>
What if you clay your motor, would you have to get another headgasket after you have clayed your motor?
NACvicSi
Nov 27, 2005 08:08 PM
NACvicSi
Nov 27, 2005 07:47 PM
Rob Dizzle
Jun 30, 2003 03:57 PM
Kellindal
May 18, 2003 10:12 PM
