RPM Bounce/Drop
Old Dec 7, 2005 | 02:50 PM
Thepanda's Avatar
Default RPM Bounce/Drop
Car:Ls/vtec
head:
crower stage 2 cams
tit springs
Block:
Eagle rods
srp pistons comp 11:1
Engine has no leaks and has been balance
Other mods:
JDM intake manifold
AEM cold air intake
Custom exhaust
What is happening with the engine is this: I have an LS/vtec. I will bring the rpms to either 2200 or 3000 and then the car will drop back to idle, If i keep pushing the gas then the car will jump back up past 3000 and it will run fine. I have only noticed this in 1st gear.
Please help me. Thank you.
Modified by Thepanda at 6:42 PM 12/7/2005
Old Dec 8, 2005 | 08:47 AM
Thepanda's Avatar
Default Re: RPM Bounce/Drop (Thepanda)
bump
Old Dec 8, 2005 | 01:41 PM
EnjoyTheRideDC2's Avatar
Sounds like an ignition problem to me....checked your plugs, wires, dizzy, cap, rotor? things of the such?
Old Dec 9, 2005 | 08:39 PM
Thepanda's Avatar
Default Re: RPM Bounce/Drop (EnjoyTheRideDC2)
Thanks. I will let you know what the status is.
Old Dec 10, 2005 | 02:40 PM
b18ccivics's Avatar
i would check the output voltage of the tps you may have a dead spot.
91 DA Revived
Mar 8, 2012 08:24 AM
luvmyh22lude
Nov 5, 2007 05:16 PM
Thepanda
Dec 8, 2005 08:48 AM
Thepanda
Dec 7, 2005 11:29 PM
SickGSR94
May 23, 2003 11:55 AM
