LSD Install, What Parts To Replace
Old Dec 6, 2005 | 10:08 PM
Jeff_B's Avatar
Default LSD Install, What Parts To Replace
I'm going to be doing a Quaife LSD install in my GSR tranny with 92k and want some advice on what parts I should replace while I'm in there...
Do you guys recommend picking up the clutch housing mainshaft and countershaft bearings? Also, should I just use new OEM enclosed differential ball bearings for the Quaife LSD?
Old Dec 7, 2005 | 06:27 AM
IN VTEC's Avatar
Default Re: LSD Install, What Parts To Replace (ChassisInnovations)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChassisInnovations &raquo;</TD></TR><TR><TD CLASS="quote">I'm going to be doing a Quaife LSD install in my GSR tranny with 92k and want some advice on what parts I should replace while I'm in there...</TD></TR></TABLE>
Differential bearings
80mm Differential shim
Axle seals
Clutch Housing Mainshaft bearing and seal
Any synchro kits where the sleeves are worn or having trouble moving up and down the hub.
Any shift forks that don't clearance properly with the synchro sleeves (replace synchro sleeves as necessary to help it clearance properly as well).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChassisInnovations &raquo;</TD></TR><TR><TD CLASS="quote">Do you guys recommend picking up the clutch housing mainshaft and countershaft bearings?</TD></TR></TABLE>
The countershaft clutch housing bearing is almost always ok to reuse. The B-series mainshaft clutch housing bearing is also usually ok, but I'd replace it anyways as a part of regular maintenance. Replace the mainshaft seal as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChassisInnovations &raquo;</TD></TR><TR><TD CLASS="quote">Also, should I just use new OEM enclosed differential ball bearings for the Quaife LSD?</TD></TR></TABLE>
Yes.
Magasin's Avatar
https://honda-tech.com/zerothread?id=795700
Old Dec 24, 2005 | 12:05 PM
Jeff_B's Avatar
Default Re: LSD Install, What Parts To Replace (Magasin)
When changing the mainshaft clutch housing bearing, it is necessary to adjust the mainshaft thrust clearance?
jdm inc
Transmission & Drivetrain
10
Sep 11, 2011 03:29 PM
mike93boost
Jul 11, 2006 02:33 AM
miyagi
Apr 20, 2006 11:55 AM
nickromeo
Mar 7, 2005 06:07 PM
RacerZook
Jul 8, 2004 06:05 AM
