Oil Pressure Light On?
Old Nov 28, 2005 | 11:46 AM
johnpa25's Avatar
Default Oil Pressure Light On?
I have a 99 Prelude base model. The oil pressure light stays on saying low on oil. It has plenty of oil and oil pressure. I changed out the oil pressure sending unit still no luck, and put a gauge on the sending unit. Has this happened to anybody else.
Old Dec 4, 2005 | 09:18 AM
ej8slim's Avatar
Default Re: Oil Pressure Light On? (johnpa25)
reset the ecu
Old Dec 4, 2005 | 01:39 PM
spidermancivic's Avatar
open in the pressure sender line?
Old Dec 5, 2005 | 11:58 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnpa25 &raquo;</TD></TR><TR><TD CLASS="quote">... and put a gauge on the sending unit.</TD></TR></TABLE>How did you do that? The stock 'sender' is just a switch. It won't drive a normal oil-pressure gauge.
Do you mean you checked it's continuity to ground with a multi-meter?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spidermancivic &raquo;</TD></TR><TR><TD CLASS="quote">open in the pressure sender line?</TD></TR></TABLE>
I think the pressure switch is normally closed. It opens when the pressure is good. So it would be a short-to-ground in the sender wire. If that's it, the idiot light would continue to be lit up if the pressure switch were unplugged.
shrirag
Apr 11, 2007 09:55 AM
Mr HYDE
Mar 29, 2007 06:02 PM
Attoir
May 20, 2006 09:13 AM
RACEPAK
Oct 24, 2005 04:23 PM
