balancer on axle?
Old Dec 4, 2005 | 03:08 PM
toooslow's Avatar
Default balancer on axle?
just installed new drivers axle on my 95 teg and noticed that old axle had rubber balancer in the middle and new one doesnt. Ive looked online and all the new axles didnt have them but the reman. did. I replaced the axle because of shaking during acceleration and the problem is still the same with new axle. is the axle supposed to have this balancer or not?
Old Dec 5, 2005 | 09:27 AM
dognutz's Avatar
Default Re: balancer on axle? (toooslow)
I have installed them with out and have not had any problems. What kind of shaking slight or severe and only on acceleration?
Old Dec 5, 2005 | 11:35 AM
dfoxengr's Avatar
Default Re: balancer on axle? (dognutz)
can you get a pic of that balancer?
Old Dec 5, 2005 | 01:02 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: balancer on axle? (dfoxengr)
I know what your talking about... I have consistantly had the same problems with axles. Mine wear out after a month or two of driving.
Finally got some Drive Shaft Shop Stage 2 axles, i have yet to install.
Old Dec 5, 2005 | 01:43 PM
gsrious's Avatar
i think what they are trying to say is the rubber "damper" on the shaft.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dfoxengr &raquo;</TD></TR><TR><TD CLASS="quote">can you get a pic of that balancer?</TD></TR></TABLE>
Old Dec 5, 2005 | 09:54 PM
JDMGirlie's Avatar
Default Re: balancer on axle? (gsrious)
are they stock honda axles or aftermarket rebuilt ones? Normaly when they are rebuilt by say AutoZone or somwhere like that they wont come with them on. And sometime it depends on what side weather it be drives side or pass. side. Thats what my boy friend says atleast. usualy the mid shaft or half shaft will vibrate alittle from the block so that kinda dampers the vibration. plus how long it is when its in the half shaft....
Old Dec 6, 2005 | 12:49 AM
sporkcrx's Avatar
Default Re: balancer on axle? (JDMGirlie)
They don't do ****, don't worry about not having it.
Old Dec 6, 2005 | 06:51 AM
You_Get_Vapors
Guest
Posts: n/a
Default Re: balancer on axle? (sporkcrx)
Stock GS-Rs have a damper, Stock Type-Rs do not. I don't know what kind of axle you have but I was told it doesnt matter.
I had Hasport Stage1s w/o a damper (made by DSS) on my GS-R and they vibrated during acceleration but not as bad as the ones with blown inner joints. My car was pretty low with lots of camber in the front and I think that attributed to the vibration as well.
MUGEN_EG95
Jan 25, 2009 05:16 AM
nonvteclude
Aug 7, 2006 08:45 PM
HondaPartsHero
May 22, 2005 09:25 PM
NstyGrnHatch
10
Feb 15, 2005 11:35 AM
FormulaGSR
Oct 5, 2004 04:34 PM
