problems repainting valve cover
Old Dec 7, 2005 | 07:05 PM
ka0s187's Avatar
Default problems repainting valve cover
so I decided to take off and repaint my valve cover. stripped the paint down to the metal with the aircraft remover, works good. sanded a lil. when I go to paint it using engine enamel 500 degrees heat resistant, the paint won't stick in some areas. leaving some dots and stuff. I'm pretty sure I wiped it off clean using soap. dunno what the problem is. its kinda cold in my garage so that might be the problem? any ideas?
Old Dec 7, 2005 | 09:11 PM
MajorPayne's Avatar
Default Re: problems repainting valve cover (ka0s187)
yes being cold will cause that and if the surface is too slippery it will also cause that, it needs to be a little rough, maybe try a primer first
Old Dec 7, 2005 | 10:08 PM
_BEN_'s Avatar
Make sure that it is free of oils and grease too. Did you wipe it down with a clean rag / acetone or alcohol? Make sure your hands are clean too when you handle it after cleaning it.
Old Dec 8, 2005 | 04:31 AM
B6tPoweredMx3's Avatar
Default Re: problems repainting valve cover (_BEN_)
The little bubbles are probably fisheyes.
Do better prep work.
Ie wash after stripped with soap and water and the allow to dry and then wipe down with a cleaner ( acetone or alcohol or grease and wax remover.)
Old Dec 9, 2005 | 05:00 PM
ccivic's Avatar
Default Re: problems repainting valve cover (B6tPoweredMx3)
Roughen it up with some sandpaper, and make sure it's clean.
C-187
Paint and Body
Apr 7, 2009 03:02 PM
Inaccurate
Paint and Body
Jan 29, 2009 08:23 PM
Squallie
10
Feb 22, 2006 12:06 PM
ebonyrolla7
Jan 4, 2006 08:10 AM
vicz
Apr 10, 2003 02:02 PM
