Help! missing bolt on valve cover?
Old Dec 4, 2005 | 08:07 PM
SteveB02Si's Avatar
Default Help! missing bolt on valve cover?
I think I'm missing a bolt on the valve cover of my 02 Civic Si 2.0?!? The location of the missing bolt is at the rear, far left corner of the valve cover. Also it looks to be threaded. I noticed an oil leak first and on further investigation saw the oil leak is at the valve cover...below the missing bolt.
Thanks for suggestions. I'm not sure if a valve cover bolt belongs there or not.
Old Dec 7, 2005 | 09:24 PM
MajorPayne's Avatar
Default Re: Help! missing bolt on valve cover? (SteveB02Si)
is there a stud there without a bolt on it?? if so then youre missing one, if theres a hole that goes into the valve cover and you cant see a threaded stud, then it probably got snapped off, they are only supposed to be torqued to like 6 ft lbs,....you can get one from the dealership for a few bucks
in the mean time put some silicon there to stop the leak
ShinotakuX
Mar 5, 2008 03:05 PM
99accordsedanforsale
Classic Hondas
Nov 12, 2007 07:24 AM
k_lude
Jan 9, 2007 06:48 PM
Cashieboi
Oct 16, 2006 09:28 PM
hcivic99
Jun 8, 2005 06:15 PM
