cam gear / valve adjustment question - decked block
Old Dec 7, 2005 | 11:18 AM
DJ Gurgla GSR's Avatar
Default cam gear / valve adjustment question - decked block
I'm rebuilding my GSR engine. My block is decked (.015) and i know the procedure for getting the cams in sinc with the crank (stake the cams at TDC - loosen adjustable cam gears, rotate crank to TDC etc etc)
My question is, should i do what i said above (get the crank & cams inline at TDC - approximately 1 degree advanced) and then do a valve adjustment? would everything be correct that way?
I read somewhere (another HT thread) to adjust the valves at 0,0 on the head and THEN adjust everything to get the crank & cams timed correctly
any info appreciated. thanks...
Old Dec 7, 2005 | 12:54 PM
Default Re: cam gear / valve adjustment question - decked block (DJ Gurgla GSR)
ttt
Old Dec 7, 2005 | 01:44 PM
JimBlake's Avatar
When you're adjusting valve clearance it makes very little difference when you're 1 or 2 or 4 degrees away from the 'correct' position. I bet if you measure it, spin 5 degrees, measure again, I bet you won't see enough difference to matter.
Old Dec 7, 2005 | 05:12 PM
Default Re: cam gear / valve adjustment question - decked block (JimBlake)
Thats good to know. i thought if the timing was a tiny bit off it would totally screw with the valve lash
ZCHondaCRX91
Feb 10, 2011 07:36 AM
95GSRBOI
Feb 5, 2007 07:24 PM
djhatchtraxxx89
Oct 4, 2006 03:46 PM
Civicman86
Jun 21, 2006 08:07 PM
RTW DC2R
Mar 23, 2005 06:13 PM
